Reverse camera retrofit …. 2016 caddy
emmD
Post by emmD »
Looking to fit a reversing camera into my 2016 Caddy maxi… want to keep the OG factory head unit ideally and save some cash…
Saw something on here about what products to buy but now can’t find the post. Would appreciate any info!!
Lockstock
Re: Reverse camera retrofit …. 2016 caddy
Post by Lockstock »
I fitted a wolfbox unit from Amazon. was 100ish quid. has a rearview mirror mounted screen. works really well.
alternative you can get the cheap camera and suitable composite cable into the head unit (provided it supports the reverse camera). the aftermarket cameras and screens tend to be better tho
DW2207
Post by DW2207 »
Hi, not sure what caddy rear doors you have, but if you go to vagtec site they sell the genuine reverse camera and wiring harness that is compatible with your factory headunit.
I went for the tailgate one for my particular van.
Was around £280 delivered.
Will need coding.
I've recorded this in my build thread.
Sent from my SM-S921B using Tapatalk
Lorente95
Post by Lorente95 »
hi, i fited to my 2017 caddy a aliexpres camera.
The + goes to a 12v relay activated by the reverse light. And in the video you get an RCA connector, you have to cut the cable, and you will have 2 cables. Those cables go to the radio unit to the blue connector (I don't remember the pins now, I would say they were 6 and 12. They are the same as in Golf 7 or Leon Mk3). Once everything is connected, you only have to code with VAG-COM.
PJD
Post by PJD »
Tried the £130 OEM retrofit mirror monitor reverse kit. Bracket was cracked and the whole kit was no better than the cheap eBay ones so sent back.
Decided to go super cheap and bought a £36 12" touchscreen mirror dash cam with reverse from eBay.
Screen not super bright in daylight but enough to do the job. Plus it provides a bit of security of a dash cam. For £36 surprisingly responsive touch screen and works better than the price suggests. If I decide on a different solution later not too much money invested.
Benson007
Post by Benson007 »
I’ve just fitted a Wolfbox G900 reversing camera with a digital mirror to my 2016 mk4. It was easy to fit and although it’s early days, I’m really impressed with it so far.
eeyuk
Post by eeyuk »
I went with the wolfbox too, was an easy fit and works well
gorelimey
Post by gorelimey »
I've got the wolfbox g900 in yesterday, any tips on the hardwire kit, what fuses to use?
