Turbo not working
Turbo not working
Hi, I have a 1.9 bls and when I start first thing in the morning from cold I let it run for a couple of minutes to warm up but when I pull away the turbo doesn’t work !! It seems to work after the engine has reached 70 + on the temp gauge, I’ve had it plugged in but it’s not coming up with any fault codes, anyone had this problem before?
Re: Turbo not working
What makes you think it's the turbo?
You seem to gave vcds - maybe do a plot of Actual and Expected air flow maybe up to 4-4.5 k revs.
