what do i need to buy to fit cruise to my caddy
morning chaps
what parts do i need to get for my caddy so i can fit cruise control??
its an 06.
thanks in advance
its an 06.
thanks in advance
C20 tdi 20" Bentley Split Rims, V Maxx Coilovers, Audi S Line Seats,W8 interior light upgrade,OEM sat nav,heko wind deflectors, Touran Black Headlights, 3 rear seat conversion, cupra r spliter, s3 gear knob, 150BHP Mapped,Fully Carpeted With Roof Leds, Touran Bumper colour coded, VW Side Rail Cover, Touran Cluster Upgrade.
MK1 Golf Fully Restored
Lexus IS200 Japtastic
Audi RS4
Instagram Vishmk1
Audi RS4
Instagram Vishmk1
Re: what do i need to buy to fit cruise to my caddy
Fitted this to my 57 plate Caddy.
GENUINE SKODA VW SEAT CRUISE CONTROL STALK SWITCH 1K0953513G9B9
Is this the only thing needed?
I would also like to do this as I do a lot of motorway work and my foot goes to sleep after a while!
Should be. No other parts required. Just replace indicator stalk & programme via Vagcom.
hi mate you need the following
control stalk
i believe midline clocks or high line as thats got the cruise control light
and mid line control module under the steering wheel but i could be wrong
yes it then just programming in vag com
if you want this all doing just ask martin spacewalker when they do the clock swap day as he'll have to do the immobilsier programming
well worth all of it bud
he provided my high line clocks and mfa stalk asi already had cruise
jas
control stalk
jas
So these clocks would need updating ?
Cruise does not require an upgrade of your cluster.
Minimum requirements are:
1. Cruise stalk,(this may need a wire to the ECU if your van does not already have it, pre 04/2006)
2. Midline Steering Wheel Control Module (Alternatively a Highline module if you intend to fit a multi function steering wheel at some point)
3. Coding and activation with VCDS or dealer VAS tool.
Clear as mud?
Clear as mud?
Far to expensive though as same switch is in the Mk5 Golf kits on ebay for around £60
We've been requested by a customer to fit cruise control and I've read up about what's involved, etc. We have VCDS too, so the programming part is not a problem. My stumbling block is that I've dismantled the dash below the steering column to try to find the part number of the steering control module. I've followed the wires coming away from the stalks and they go into a box but it doesn't seem to have a valid VW part number (i.e. "1K0-###-###-#"). Can anyone explain exactly what the box looks like and its location or even better, post a photo please?
If the image link is working, here's a snap I took of the label on the box that I think must be the right one, but as you'll see, those numbers are nothing like VW part numbers!
Do a scan with VCDS and post the 'steering wheel' info from there.
have caddy maxi non mfsw & non mfd no special requirements. i fitted cruise stalk and midline steering box the data wire is in pin 13 under column black/white tracer have scanned it and entered coding as i thought correct but nothing its the code for steering module i cant sort out it accepted the code for cruise 11463 (anyone in northants area thats actually done one of these) i am not experianced with the coding of modules so need step by step instructions ??? or somone whos done them
There is a very informative how-to topic on the forum.
Get your post count up for access.
