Fuel tank sloshing around?
I have just brought a 2010 caddy, i filled it up the other day and you can really hear the diesel in the tank spashing around and knocking the sides of the tank really loudly! Is this normal? Anyone else having this issue?
Re: Fuel tank sloshing around?
Yeah mate defo normal thats were dynamat comes to the rescue
Or whatever sound proofing you choose but its defo nothing to worry about
Yes, it's the small things that p**s me off. I packed out the two spaces behind the seats with sleeping bags this helps and if I get stuck at night won't get cold.
Haha sleeping bags is a brilliant idea! I spoke to someone at a vw garage and they said there is an option for a new tank that may stop this, you know anything about this?
A new fuel tank is going a bit too far.
- chezzy71
mines all sound proofed with similar to dynamat and its much better now, still hear it but not as much, seems to happen more with about 3/4 of a tank
viewtopic.php?f=13&t=10101
Is dynomat really that affective? Where about are you applying it?
I covered my hole floor every single bit covered and it helped a good bit still hear it a bit though.
- Ripley55
I know this is an old post, and nothing on it for a few years, but the last couple of weeks (Since I've gone down from 19's to 18's) I've noticed, and can clearly hear diesel sloshing about in my tank !! I'm at just over half a tank today coming in to work, and it was very pronounced when I came out of the drive. I'm a Maxi Life, so not as if there's no soundproofing or anything.
Can anyone explain why I've just started noticing it ?? Cheers
Hi @Ripley, did you ever get a response around this? I've recently purchased a 17 plate caddy and experiencing the same issue. Wondering what you might have done to fix it? The sleeping bag suggestion might be a good idea as I currently don't have any use for the spaces behind the seats.
Thanks, Phill.
Thanks, Phill.
New Caddy owner - 67 Plate - Grey 2.0l TDI Highline
Van is currently for running around but turning it into a "day camper" - basically putting a bed in the back so I can travel the UK and use it as a posh tent
