show me your seats!
Ragehart
Re: show me your seats!
Post by Ragehart » Mon Jun 18, 2018 6:10 pm
Its torque bolts isnt it ill borrow by mates set.
Caddyluv
Post by Caddyluv » Mon Jun 18, 2018 6:15 pm
Don’t know what there called. If you get Touran bases ask if you can have the M10 bolts that go with them. You caddy bolts are smaller M8.
mostlysimon
Post by mostlysimon » Mon Jun 18, 2018 8:03 pm
Not torque, they're spline bolts. I begrudgingly bought a set when I changed my seats but I've used them loads since then for all sorts.
Ragehart
Post by Ragehart » Mon Jun 18, 2018 8:30 pm
Yes i found this out earlier but forgot to post as number 1 injector just went so ive been trying to sort that out Image
Ragehart
Post by Ragehart » Tue Jun 19, 2018 6:44 am
Ol so the man about the seats just got back to be amd said £80 for the bases. Is that a good deal? Thanks for the link jd2k
Caddyluv
show me your seats!
Post by Caddyluv » Tue Jun 19, 2018 6:47 am
Yeah if they are in good nick. I promise you if you can get the bolts thrown in two.
You might be able to get cheaper but you said you want it now so £80 with bolts and posts. Not bad.
Ragehart
Post by Ragehart » Tue Jun 19, 2018 6:49 am
Well the seats look a mess what do i look for on bases? Do you mean 2 minutes to fit?
Ok i get you thanks ill try and knock him down a little and its only 45-60 mins drive away. Thanks caddyluv
Caddyluv
Post by Caddyluv » Tue Jun 19, 2018 6:59 am
The seats with Touran base will take you around 20-30 mins each one to fit. You can hide all the wire harness for your power in the Touran base. And you have the little draw for stuff.
Ragehart
Post by Ragehart » Tue Jun 19, 2018 7:45 am
Ok great thanks
JD2k
Post by JD2k » Tue Jun 19, 2018 9:15 am
I paid a £100 for mine but they were pretty much in perfect condition. So £80 isn't bad if they're in good condition
Ragehart
Post by Ragehart » Tue Jun 19, 2018 9:23 am
Just got them for £70 with bolts
Caddyluv
Post by Caddyluv » Tue Jun 19, 2018 9:27 am
Sweet bargain well done. Honestly it will make the job so much easier.
Ragehart
Post by Ragehart » Wed Jun 20, 2018 9:46 pm
Put the touran bases in and q5 slines in. So much nicer. Will put a pic up of both in the morning. And yes about an hour ro put in as 1 bolt hole was cross threaded to had to get dye kit to re rhread hole. ImageImage
Caddyluv
Post by Caddyluv » Wed Jun 20, 2018 10:04 pm
You can see it was easier with bases ha!
Ragehart
Post by Ragehart » Wed Jun 20, 2018 10:20 pm
Yes very easy with correct tools and holes. Only problem was cross threaded in base thanks again
