show me your seats!
marshall91t
Re: show me your seats!
Post by marshall91t » Mon Jul 23, 2018 7:03 pm
notagasman wrote:Are they leather?
Sent from my ONEPLUS A5000 using Tapatalk
Nahh, they have small strips of leather (the black bits) but are mostly fabric.
Sent from my S60 using Tapatalk
Ell.s
Post by Ell.s » Fri Jul 27, 2018 1:35 pm
Audi A1 sline half leather, direct fit to caddy bases.
eddyrey619
Post by eddyrey619 » Tue Jul 31, 2018 9:45 am
Joepayne1 wrote:
Wed Apr 13, 2016 7:39 pm
Golf R leather
Joepayne1 I just bought the same seats any advice you can give me In regarding the install and did you wire the heated seats and the airbag in
michalsowa1990
Post by michalsowa1990 » Wed Aug 01, 2018 9:55 am
Polo 6R R-Line on standard bases.
Marcoaus90
Post by Marcoaus90 » Wed Sep 02, 2020 1:23 am
Hi Everyone - I'm planning to buy the Audi A1 2011 seats.
I own a Caddy 2007 and I was wondering if such seats from the A1 would be a direct swap.
Or I need anything custom?
Ryzar1
Post by Ryzar1 » Wed Sep 02, 2020 1:36 am
Pretty sure a1 seats bolt straight on no drilling required
Sero62
Post by Sero62 » Thu Nov 05, 2020 8:54 am
I'm mounting my 7R seats in my caddy 4 right now. Can anyone help me and tell me how to wire them? Both seats are heated, and have airbags in the seats. No electric seat adjustment.
Cabbs
Post by Cabbs » Sun Nov 08, 2020 12:25 am
[mention]Sero62 [/mention]
You need to purchase the correct heated seat controls and retrofit loom.
[mention]tommyzooom [/mention] may be able to help you with the parts you need. I have just fitted the loom to my 7.5 R seats but it will be different as mine is a facelift Mk3 with basic heater controls.
Sero62
Post by Sero62 » Mon Nov 09, 2020 8:00 am
The thing is I can't send private messages yet :cry:
No one else there that can tell me how to wire?
Cabbs
Post by Cabbs » Mon Nov 09, 2020 8:10 am
Yes we have all been there at some point post building. It’s just the general rules of the forum and easy to participate in order to build your post count.
They aren’t straightforward to wire up. You will need a new heater control panel, loom, heated seat module and coding,in order to do it safely and
have the factory fit look.
Sero62
Post by Sero62 » Sun Nov 15, 2020 12:05 pm
Thanks for your reply, are you sure i need a new heater control panel and heated seat module? like already said i have a caddy 4, from 11/2018, and my factory seats already were heated?
The golf 7 seats, have 1 wire more than my caddy factory seats.
BritishGasBlue
Post by BritishGasBlue » Sun Nov 15, 2020 1:13 pm
So the simplest fit would be to get Touran seats already on the bases? (My bases could do with replacing) as the plastic has snapped) I just need new seats ideally ones which fold flat. Anyone in London who could do the lot?
Sent from my SM-F907B using Tapatalk
Last edited by BritishGasBlue on Sun Nov 15, 2020 1:13 pm, edited 1 time in total.
Philnanks
Post by Philnanks » Sun Nov 15, 2020 1:13 pm
Heated Golf GTD seats. I already had heated seats so just had a loom supplied by Stantheman.
Iridium grey 2016 Caddy Maxi Life 150 DSG
Marin97
Post by Marin97 » Sun Nov 15, 2020 1:25 pm
Help needed! Question i think everyone have:
I read somewhere that if i wanted golf 7 seats i have to have touran's base for them to be almost perfect match?
In my caddy i have airbags in seats but i don't have electronic adjustments that i want to have with new seats is it possible?
I believe that term is retrofitting..?
Also what about back seats?
What seat to use in back, are they all same for golf touran caddy etc?
Should i buy 3-door or 5-door seats?
Thinking about these seats from my local buynsell site:
1. IDK model but r line
https://www.njuskalo.hr/image-w920x690/ ... 230419.jpg
https://www.njuskalo.hr/image-w920x690/ ... 230420.jpg
2. Golf 7 r line seats
https://www.njuskalo.hr/unutrasnjost/go ... s-31489734
3. Golf 7 gtd seats
https://www.njuskalo.hr/unutrasnjost/vw ... s-30551415
4.Golf r line
https://www.njuskalo.hr/unutrasnjost/vw ... s-31098862
5. Golf 7 seats alcantara
thanks!
:mrgreen: :mrgreen: Caddy VAN 2017 TDI DSG 6-speed 102hp :mrgreen: :mrgreen:
Pics:
https://ibb.co/album/8bB8TJ
Lister79
show me your seats!
Post by Lister79 » Sun Nov 15, 2020 4:38 pm
Hi to fit the MK7 seats you can either fit Touran seat bases which enable a straight fit, or you can drill the Caddy seat bases for the fixing holes and the peg that’s on the underside of the seat.
To wire them in [mention]Stantheman [/mention] or [mention]tommyzooom [/mention] produce the looms so that everything will work as factory.
Rear seats, only the Caddy life or Touran rear seats will fit properly.
You may be able to make golf seats fit but I imagine it will be more work than it’s worth compared to the life or Touran ones, which are relatively simple.
2014 Toffee Brown 1.6TDi
