20v turbo engine conversion
Jdk
Re: 20v turbo engine conversion
Post by Jdk » Sun Aug 09, 2015 7:30 pm
That's at leat 3 of us with the 20v turbo engine on here then! My donor car was an Audi S3 so used the s3 throttle welded into place, custom 3" inch exhaust (de cat) made, and also had to re route washer bottle as turbo pipes in the way. I did not have the know how to do the wiring myself, but I have learned a lot about the workings of the electronics of a modern car in the process as I have been guilty of just sending my car to the garage before getting this project. (much respect mrpurple) I have the 6 speed 4wd gearbox in the van, and am looking at the possibility of connecting this up in the future. I also have the imomabilzer deleted, but had a that that thatchem alarm fitted for the insurance
mrpurple
Post by mrpurple » Sun Aug 09, 2015 7:37 pm
I was going to use the 4wd box, it was bolted in wit the first engine but was making a knocking so I changed it for a 2wd one as I didn't have time to strip the box down and fix it, van was booked to go to to MIVW so really didn't want to miss that. May go 4wd at some point, bit beyond my capability is fabricating the haldex rear end mounting but luckily I know a man that can.
'56 Caddy 1.8T
'15 BMW R1200GSA
'81 Mk1 Golf 1.8T
bud the spud
Post by bud the spud » Tue Aug 18, 2015 7:35 pm
well due to a bls rod coming out the engine block my engine conversion has been stepped up a gear
caddy engine is out and the tt engine is now in the bay with cam belt and water pump and clutch done today
drive shafts are next on the list
:mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen:
Gibbo
Post by Gibbo » Tue Aug 18, 2015 9:18 pm
bud the spud wrote:well due to a bls rod coming out the engine block my engine conversion has been stepped up a gear
soungs good keep us posted
Jdk
Post by Jdk » Sat Aug 22, 2015 7:27 pm
Good lad, wiring next but remember the end game, big smiles in a quick caddy
bud the spud
Post by bud the spud » Sun Aug 23, 2015 5:50 pm
well today drive up to durham to drop off touran rear seat conversion and drop off wiring to a man up that way
bud the spud
Post by bud the spud » Mon Aug 24, 2015 7:22 pm
Looks like the whole van has to come apart to get wiring loom out
Much joy i say
Jdk
Post by Jdk » Tue Aug 25, 2015 7:23 pm
I had the loom, clocks and keys from a donor with a view of changing these over. However when I took the dash out and looked at the size of the job, went down the route of modifying the existing harness as an easier route. Good luck with the job and will watch with interest so keep us informed.
mrpurple
Post by mrpurple » Tue Aug 25, 2015 8:50 pm
Best way to do the wiring is to integrate it into what you already have. Not worth taking the whole loom out to modify it that way as it's more work than is necessary and will not be as well done as a loom that is built in situ, with all the wiring put into the right place and then properly wrapped when complete. That's just my opinion and with something like this there are many options to do it.
'56 Caddy 1.8T
'15 BMW R1200GSA
'81 Mk1 Golf 1.8T
bud the spud
Post by bud the spud » Wed Aug 26, 2015 6:51 pm
well took out the dash today and must agree with mr purple about doing the loom in situ,more agg but need doing
NZDubNurd
Post by NZDubNurd » Thu Aug 27, 2015 9:48 am
mrpurple wrote:Best way to do the wiring is to integrate it into what you already have. Not worth taking the whole loom out to modify it ...
It's a MAJOR job to remove everything!
I'm making diagrams and cross reference charts for my R32 conversion in the Touran - a lot of the ECU wires can be swapping directly into the ECU connectors for me, and the few wires that need adding, can be run to the fuse boxes or connectors, and fitted with the correct terminal to fit. The car itself will be staying basically intact, and the add onswill be fitted to look as OEM as possible.
Doing it in place makes it easy to fit the correct lengths, and run them the right routes, without stressing or breaking wires.
Regardless of what way you're most comforatble with, it's a lot of work!
Well done guys - and GOOD LUCK!
dan@biali
Post by dan@biali » Thu Aug 27, 2015 10:49 am
Looks like a fun job! This is MDM converting my loom to GTi ED30. They stripped both out and repinned the whole thing.
bud the spud
Post by bud the spud » Wed Sep 09, 2015 7:19 pm
drive shafts done today,and fuel pump is a mix of caddy top and tt guts of the tt pump.
all I need to do is check that it works and put it back in tank and refit the fuel tank
bud the spud
Post by bud the spud » Thu Sep 10, 2015 7:52 pm
Fuel tank back in and lines done today
Gibbo
Post by Gibbo » Thu Sep 10, 2015 9:18 pm
Keep up the good work can't wait too see hear the end result !!
