roof whirly fan
PaulieB
roof whirly fan
Post by PaulieB » Mon Feb 23, 2015 7:54 pm
hey guys, I pick my very first caddy up this coming Saturday and I can't wait! The only thing I dislike about my new toy is the disgusting whirly vent on the roof which is mounted at the rear right hand side (why it couldn't be mounted centrally I don't know?). Has anybody removed said fan and if so how have you filled the hole which I believe is around 100mm in diameter?
paul
If it weren't for bad luck I'd have none....
torque777
Re: roof whirly fan
Post by torque777 » Mon Feb 23, 2015 8:45 pm
Maybe weld a plate in?
kirade
Re: roof whirly fan
Post by kirade » Mon Feb 23, 2015 8:48 pm
I had one in mine horrible thing, tiger sealed a round repair panel that I had in the body colour, left a large weight on it overnight to keep it flat, had no issues with it, and a similar patch on roof lining before carpeting.
Mike
PaulieB
Re: roof whirly fan
Post by PaulieB » Mon Feb 23, 2015 9:41 pm
Cheers for the replies, I thought of sikaflexing a pre painted small metal panel inside the roof then maybe filling the hole on the external roof surface with maybe glassfibre then bodyfiller but I'm unsure whether this would work?
dubvan
Re: roof whirly fan
Post by dubvan » Mon Feb 23, 2015 10:14 pm
I had one on a Vauxhall Combi once. Made a hell of a racket; I hated it! Most efficient and aesthetic way of getting rid, is to weld a plate in and paint it. Just my opinion, bud.
PaulieB
Re: roof whirly fan
Post by PaulieB » Tue Feb 24, 2015 4:20 am
Cheers Dubvan... I know one thing for sure, one way or another it's being removed! :D
714priest
Re: roof whirly fan
Post by 714priest » Tue Feb 24, 2015 10:39 pm
i had a roof light in mine the hole was alot smaller but i used fiberglass and filler. i also used fiberglass to fill in some BIG rust holes in my mate mk2 caddy they were 6"plus size holes and it works well
do you dig it
PaulieB
Re: roof whirly fan
Post by PaulieB » Wed Feb 25, 2015 4:56 am
Cheers 714PRIEST, I may have a go at that rather than having a blanking plate on show! :)
714priest
Re: roof whirly fan
Post by 714priest » Wed Feb 25, 2015 9:43 pm
i did it because i dont know how to weld or have the gear to blow myself up trying. fiberglass is easy but id watch some youtube videos on how to use it 1st.
do you dig it
PaulieB
Re: roof whirly fan
Post by PaulieB » Thu Feb 26, 2015 5:58 pm
Will do buddy.. Cheers for the advise! :D
mikeb1810
Re: roof whirly fan
Post by mikeb1810 » Wed Sep 16, 2020 2:08 pm
Hi all,
I realise this is an old thread, but seemed to make sense to carry this on rather than make a new one.
I am looking to remove the vent from my ex BG van and was wondering if I could get a plate slightly larger than the hole and use some metal adhesive to hold it in place
does anybody have any experience of this?
I am guessing it doesn't have to be that strong as it isn't load bearing, but should be flexible / waterproof.
Once cured I was thinking I could use some body filler and spray paint to smooth it out.
Thoughts?
Caddyluv
Re: roof whirly fan
Post by Caddyluv » Wed Sep 16, 2020 2:42 pm
Well I don’t have experience but cars are now being built with glues. So I assume if what ever they use is strong enough for a plate.
If your going to the effort of painting it, why not get it welded and respray the roof.
mikeb1810
Re: roof whirly fan
Post by mikeb1810 » Wed Sep 16, 2020 9:43 pm
I'd feel confident doing the adhesive and spray myself. It doesn't have to look perfect as its on the roof, I just want it to be functional.
I don't have any welding gear (or much experience welding!). If there was a solution that I could do myself that would be great.
