150bhp turbo
150bhp turbo
has any of you guys out there fitted a 150hp gt tdi turbo to a 104hp caddy before?
- colm1988
Re: 150bhp turbo
It has been done but i think u need to change injectors and fit bigger brakes to stop ur ass from hitting poor sheep thay may walk on front of ur thundering beast. And I think with power you get smoke
€10 to fight a lad in the back of a trailer? I'd do that!"
Re: 150bhp turbo
well ive taken the old turbo off, im fitting the new 150hp one tomorrow so if it goes to plan i should be back on the road very soon
- Cd05
Re: 150bhp turbo
Its on there but not a 100% direct replacement/fit. The exhaust flange on the downpipe are different, so ive machined up a flange and made my own downpipe and removed the cat.
Also the egr valve pipe to the manifold mounting position is slightly different, so ive blanked it off and hopefully on monday when i get it remapped again, i should be able to delete the egr from the ecu cus at the mo it goes into limp mode frequently.
Re: 150bhp turbo
Good stuff let us know what power she makes
Re: 150bhp turbo
Did you have to change injecters or anything
1.9Tdi 104 Window Tints Wind deflecters
To Come: Alloys, Touran Bumper, Colour Code, Spoiler, Front splitter, Front Fogs, Smoked Headlights, Remap
Re: 150bhp turbo
no, havent changed anything else yet, was thinking of ripping the guts out of the egr valve as its not going to be needed but undecided at the mo, surely it will be less restriction into the inlet manifold.
Does anyone know if this is a good idea or not?
- hedge
Re: 150bhp turbo
removing egr is good! you will get an engine management light on so when you get it remaped ask them to remove the egr from the mapboloclips wrote:no, havent changed anything else yet, was thinking of ripping the guts out of the egr valve as its not going to be needed but undecided at the mo, surely it will be less restriction into the inlet manifold.
you can remove the guts but I would blank it off and use a egr removal kit or just blank it off,
egr's get good money on ebay so remove it and sell it!!!
Re: 150bhp turbo
cheers for the advice,
where do you get a removal kit from?
- hedge
Re: 150bhp turbo
If you want to do just the blanking plates and remove the pipe between the manifold and egr (this is what I did)
order two of these http://cgi.ebay.co.uk/EGR-blanking-plat ... 0636514744" onclick="window.open(this.href);return false;?
or for the full hog
http://cgi.ebay.co.uk/EGR-Replacement-R ... 0722363532" onclick="window.open(this.href);return false;
(cheaper than I remember!)
or the orignal
http://shop.ebay.co.uk/i.html?_nkw=alla ... 86.c0.m359" onclick="window.open(this.href);return false;
or for the full hog
or the orignal
Re: 150bhp turbo
nice one cheers
