looking for wheel arches
hey can anyone tell me whats out there in a wheel arch trim for the caddy that still allows the sliding doors to open. id love something mk2 g60 golf size but only coming across little 20mm stick on things
Re: looking for wheel arches
these are the best i can find
http://www.ebay.co.uk/itm/VW-CADDY-03-1 ... OxyeglTZ4z~" onclick="window.open(this.href);return false;
- Gresley
Google caddy cross. You could use those arch trims but they are not cheap.
- dan@biali
And they have to be colour coded unless you have twin sliding doors because they only come on a twin sliding caddy so have joins in them and you can't match up the factory textured finish after you've plastic welded a couple together to make the offside trim.
Hi dan, have you a link to where you can get them from as I'm after a set for my maxi twin sliding van
The Caddy Cross or Alltrack kit is a genuine VW part so your local VW parts counter is probably your best source.
If you are in the UK: https://www.volkswagen.co.uk/owners/vol ... uine-parts
- dan@biali
There are a few people on here using the vanstyle arches https://www.vanstyle.co.uk/van/black-o ... -6835.html which are a lot cheaper but a couple of mm smaller than the Cross/Alltrack ones. They’re listed as only for 2015 onwards and left side slider but can be modified to fit if you’re plan is to paint them.
can the van style ones be modified to fit 2015 pre facelift model?
I have double sliding doors but don't mind modifying them as will be painting them. Just unsure how they will line up.
cheers in advance
cheers in advance
- dan@biali
Yes, Barbell330 has fitted them to his.
Page 44 onwards https://caddy2k.com/forum/viewtopic.php ... &start=645
Nice one, cheers for the reply
