You can, however it's expensive and mostly cosmetic (and all plastic!). There is an under-engine tray, but I believe that is the same (plastic) OEM one people are fitting on here. I wouldn't bother that much with the metal one, as anything you hit that can break the plastic (it's tough!) will cause you issues regardless of what the tray is made of...Robin UK wrote:I wonder if you can get the Caddy Cross trim OEM. The arch protectors at least might be a good idea on my van if they fit. Also, do the under carriage guards extend further than the bumpers? Are they plastic or metal? I was tempted by the aluminium engine tray/protector from the site linked above, but they're a bit more than I want to spend just now.
You can find the part numbers somewhere in here:
http://www.caddy2k.com/forum/viewtopic. ... 50#p128050" onclick="window.open(this.href);return false;
