Barbel330
Post
by Barbel330 » Tue Feb 21, 2017 6:19 pm
Instagram: @y_5cuf
Gary3084
Post
by Gary3084 » Tue Feb 21, 2017 10:06 pm
They look sweet, how long did they take to do? Did you notice a big difference in stopping power?
Barbel330
Post
by Barbel330 » Tue Feb 21, 2017 10:13 pm
Half an hour to strip down, took the outer caliper and carrier to the powder coaters and while they were there (a few days) I took the pistons and seals out of the silver side of the caliper, cleaned them up and I guess about an hour or so to fit new seals and pistons. Then bolted the 2 halves together when I got them back after powder coating and sealed the whole lot in ceramic sealant so they're easy to keep clean. Fairly easy job all round really.
Certainly a decent improvement in brake performance over standard.
Instagram: @y_5cuf
Marcosdediego
Post
by Marcosdediego » Wed Feb 22, 2017 11:53 am
I you have to know That if you upgrade in the front you must upgrade in the rear, the best upgrade in the rear are 310 vented disc and calipers from audi tt 3.2, mk5 r32. If you only upgrade the front when you break you will fell that de van incline to the front and thats not good to the wieght balance, the van must brake flat.
kpowell911
Post
by kpowell911 » Sun Nov 11, 2018 1:13 pm
Barbel330 wrote: ↑Tue Feb 21, 2017 10:13 pm
Are your HEL lines standard Audi S3 ones or are they custom VW Caddy one end, to S3 the other end?
Heres what I have so far
Barbel330
Post
by Barbel330 » Sun Nov 11, 2018 1:48 pm
Pretty sure they were S3 hoses but it was a while ago when I bought them so can't really remember. Just phone or email Hel, they'll tell you exactly what you need.
Instagram: @y_5cuf
kpowell911
Post
by kpowell911 » Sun Nov 11, 2018 1:53 pm
Barbel330 wrote: ↑Sun Nov 11, 2018 1:48 pm
Ill drop them a call/email. Can only see sets fo 4 on their website however.
Did see this, wonder if I can find out the necessary connections and use this option
http://auto.helperformance.com/custom-brake-hose
karlos0891
Post
by karlos0891 » Sun Nov 11, 2018 1:54 pm
s3 hoses or mk5 r32 hoses will work fine. the end on the body is same across caddy touran passat a3/s3/rs3 golf mk5s
Barbel330
Post
by Barbel330 » Sun Nov 11, 2018 1:55 pm
They sell them in pairs too, fronts and rears. They're very helpful if you call them.
Instagram: @y_5cuf
kpowell911
Post
by kpowell911 » Sun Nov 11, 2018 2:20 pm
karlos0891 wrote: ↑Sun Nov 11, 2018 1:54 pm
Brilliant, I thought as much, Ive been comparing the Ekta's between the S3 and my Caddy and was close to that conclusion, but great to have it confirmed!
Just realised I need bolts too. Theyre not cheap are they!!?
karlos0891
Post
by karlos0891 » Sun Nov 11, 2018 2:22 pm
be same bolts as passat uses they are i think £10 ish for 2 on ebay not sure about from dealer i need to get some
karlos0891
Post
by karlos0891 » Sun Nov 11, 2018 2:29 pm
kpowell911
Post
by kpowell911 » Sun Nov 11, 2018 2:40 pm
https://www.ebay.co.uk/itm/173339005140
Bought 2 sets of those (4 in total) and the hoses. Just need to let the finds build back up and ill get them fitted and the coilovers wound down a touch
Davies-a25@sky.com
Post
by Davies-a25@sky.com » Sun Apr 04, 2021 7:34 pm
I’ve been looking to do same but looking to go down brembo 18z route which should offer great stopping power as from much heavier vehicles such as Porsche cayennes etc!
How do I get access to technical pages on this site? Has anybody had experience of doing this?
I’ve seen fitting kits on dark side etc and know now need ml 450 disks! Do I need to change stone guard at rear ? If so what one do I need and do I need to change to bigger master cylinder?
Thanks in advance sorry for highjack!
Scoobysrt
Post
by Scoobysrt » Sun Apr 04, 2021 10:35 pm
How to gain access is in your welcome email I believe but also stickied at the top of each section with more info in the new member section of the forum.
