Caddy gen 4 cluster coding
Hi tried fitting highline clocks to day but had no joy the new caddy clocks have component protection on. So the earlier clocks haven't dose any one no how to sort it.
Re: Caddy gen 4 cluster coding
hey bud component protection cannot yet be turned off in the clusters, in fact i think the only way to get a cluster upgrade for the gen 4 caddy is to buy a new one (unfortunately i am in the same boat)
for further reference the only way to reset cp (which will switch back on again in 8 hours if the part doesnt come from the vehicle chassis or isnt registered with the vw fazit server) is to use ODIS (authentic dealer software) or an indy with pass thru and GeKo access
Hi fella I no it's not good I am buying a new set tomorrow.
What set you buying?
I intend to keep an eye out and see but ideally id like another set of 3d ones
If you are buying new from VW, you might as well have Colour 3D, they are all the same price.
Hi they don't do them for the caddy so I had to get standard ones component protection in the new caddy clocks
and here we go folks, gen 4 low-line to high-line retrofit
Low-line High-line in but not yet coded to the van (zoomed in) High-line in but not yet coded to the van (zoomed out)
VCDS (VagCom)
VAS / ODIS VW Audi Seat Skoda (Dealer Level / Online Access / Component Protection / Keys / Coding)
VagCAN PRO
AVDI
VagCAN PRO
AVDI
High-line now coded to immo and running zero miles
High-line with mileage adjusted
VCDS (VagCom)
VagCAN PRO
AVDI
VagCAN PRO
AVDI
Nice work.
That is a new instrument cluster adapted with ODIS?
yes brand new cluster adapted with ODIS all the way, too new for AVDI as yet
VCDS (VagCom)
VagCAN PRO
AVDI
VagCAN PRO
AVDI
Is there no compatible 3d clocks with the caddy I.e scirocco or mk7 golf
Mk7 golf is different immo system
VCDS (VagCom)
VagCAN PRO
AVDI
VagCAN PRO
AVDI
I'd have thought one of the last 1T Touran clusters would work but maybe not. The 5T Touran is MQB platform so that is ruled out immediately, just as the mk7.
The old Tiguan maybe an option but I'm not sure is ODIS will kick it out due to mismatching part numbers and comparability with handbrake etc.
I'm thinking the rocco r line may be an option, will give my local tps a buzz and see if they can help out, don't mind trying a few things out with odis
one like http://usedcars.volkswagen.co.uk/Sciroc ... c=se_na_re_" onclick="window.open(this.href);return false;
it features colour cluster and no epb as std
