Subs behind seats
sharpy52
Subs behind seats
Post by sharpy52 »
Is there a off the shelf box for a 10in sub that fits in the space under and behind the passenger seat on a mk3 caddy. Dont really have the time or skills to make somthing myself.
josh487
Subs behind seats
Post by josh487 »
I'm the same and also Intrested in doing this here for the comments lol
Chris017
Re: Subs behind seats
Post by Chris017 »
I have tried fitting a vibe 10 inch cbr with no joy so still in the back now lol. Will have to be a custom box I think easy enough to do to hide it away but you might loose some bass at the same time then.
sharpy52
Post by sharpy52 »
Yeh I've been looking around and can't find anything to fit. Looks like its a trip to buy some mdf this weekend!! Have the solid plastic bulkhead in so needs to be somewhere in the cab
Chris017
Post by Chris017 »
I have no bulkhead so will just pull the seat out and measure away. Plenty of room in there for a 10 inch maybe even 12. Think it will be a good idea to make it a tilted box if you know what I mean. And fix the amp on the box also so use up the room. I will be making one soon when I have time and will be using all the parts from the vibe I have. Will try to replicate the vibe box just with smaller dimensions.
NZDubNurd
Post by NZDubNurd »
There is about 100mm of insulation under the front seats - I'm mounting a battery box under the seat for my Touran R32 conversion.
Certainly if you remove the insulation, carpet and the drawers under the Touran seat, you can get 200mm+ of height in there.
Dunno if that helps with a sub... but I thought I'd say anyway :lol:
Fukpig
Post by Fukpig »
I've got 2x 12 JL subs in mine I've cut out the plastic bulk head and fitted the box in there.the subs are behind the seats and the air port blows into the cab too. None of the back vibrates just the interior light
donnielee
Post by donnielee »
ive got 2 15s mounted infinite baffle behind my seats
Big Pimp
Post by Big Pimp »
If you have kept the bulkhead surely you could just go smaller and fit a couple of 8" under the seats! I know I've got loads of space under mine.
It may be on the small side, but measure the space you have available and then check who does subs which can handle the cu/ft space you have
RKDesigns
Subs behind seats
Post by RKDesigns »
I made a new flat 18 liter box and used a Alpine 8" woofer swe 815... very good price quality. It comes with a super small receiver with controller so thats superb. Will be an easy fit even with the oem headunits which not support subs. Went partly under and behind the passenger seat.
Chubby
Post by Chubby »
I was looking at this today. And thought about using 6x9 speaker boxes. In both parts beheind seats. Lot of wasted space there.
gohie
Post by gohie »
i run a vibe Optisound 8. fits under seat a treat and has got enough bass for my solid bulk head cabin. i use the van for work gear so i have no space to have one in the back. paid £135from fleabay and comes with all the wires and its active.
http://www.halfords.com/technology/car- ... -enclosure
it even surprises me sometime how good it is. arm on the window and feel the rumble!!
Supercharged Performance LTD,
"Suffolk's Premium Mobile ECU Remapping Service"
www.superchargedperformance.co.uk
Contact@Superchargedperformance.co.uk
07929333153
sharpy52
Post by sharpy52 »
As an update, i made a custom box and now have a 10in focal sub under/behind the passenger seat
B18njy
Post by B18njy »
Sharply, got any pictures as I want to Chuck a sub in the same place then replace the door speakers and insert tweeters on the dash with a new headunit, ideally keeping the bulkhead unless I can a new one.
Ben
DW2KN
Post by DW2KN »
I use and Alpine with integrated sub, really nice and balanced with upgraded door speakers and 6x9 in the back.
Sent from my SM-N975F using Tapatalk
