MK5 golf GTI steering wheel fit facelift caddy?
gohie
Post by gohie »
Will these fit? TIA
Supercharged Performance LTD,
"Suffolk's Premium Mobile ECU Remapping Service"
www.superchargedperformance.co.uk
Contact@Superchargedperformance.co.uk
07929333153
Re: MK5 golf GTI steering wheel fit facelift caddy?
Fit - yes
Work - only on some
gohie
Post by gohie »
Doc wrote:Fit - yes
Work - only on some
This one I'm looking at doesn't have buttons.... airbag will be okay thou right?
07929333153
If it has no buttons you'll be fine.
You will need the mk5 airbag to fit the wheel
gohie
Post by gohie »
Doc wrote:If it has no buttons you'll be fine.
It comes with the airbag! So cool all good thanks
07929333153
Super64
Post by Super64 »
Will the early caddy airbag fit the gti wheel?
It’s the same shape.
Yes, the Caddy 2006-2010 uses the same airbag as the mk5 GTI.
Super64
Post by Super64 »
Thanks, I’ve just ordered a gti wheel off eBay with a deployed bag so I’ll fit mine. I’m assuming the wheel is a straight swap.
Tom Murphy
Post by Tom Murphy »
Apologies for digging up an old post.
I have been offered a good flat bottom mk5 GTI non MFSW and just wondered did the horn work oproperly and airbag connect directly to the facelift Caddy. Mine is 2012.
Many thanks in advance
