Mk4 rear bumper on a mk3.
Re: Mk4 rear bumper on a mk3.
@Zak Looks good
Anyone priced this bumper?
- Afield23
I was quoted £650 genuine VW part painted and fitted by an independent body shop, VW wanted £909 plus VAT painted and fitted. I highly recommend second-hand seen some for around 250€ delivered from the Netherlands but then obviously you may need to add paint and the addition PDC module etc
Waiting for new front bumper before colour coding but this mk4 bumper is so easy to fit 6 screws. 2 on each wheel arch then 2 in the rear metal bar.
2011 1.6 TDI - ex british gas caddy maxi http://caddy2k.com/forum/viewtopic.php?f=3&t=30795
Mk4 rear lights, Auto headlights, Passat w8 interior leds, 18" supermetal bullets, Polo MFSW, Touran doorcards exit lights, carpet sports seats & storage bases. VanX glovebox, Audi air vents, Sirus rear seat conversion, Privacy rear windows, RCD 330 CarPlay, Speakerupgrade underseat sub, Leisure battery, 3000w inverter.
- Markham92
so my mk3 sensors won't fit and I'll have to get new ones? I'm looking at getting a bumper with reflectors in
- Afield23
I think it's the brackets that make the difference, older sensors will fit but you'll need the old style brackets. Also, some bumpers have 6 sensors I believe, 1 each side and 4 at the rear.
Mines just aftermarket sensors. Easy to fit as the factory holes are below the metal bar. Factory holes just needed widening by 5mm.
I got a set that fit in the mk 4 bumper perfectly. About 45.00. And theybare angled like they should be. Fitted right in the factory holes.
Sent from my SM-N950F using Tapatalk
- Beaker2135
The 6 sensor ones have Park Assist, the four sensor ones are for PDC
Hi, have you got your head around this yet?
What do you need to fit the old PDC sensors to the new bumper. Part numbers would be good
- Afield23
No this is on a back burner for me but from previous advice the old sensors will fit if you use the mk3 style sensor brackets otherwise you need to new sensors and possibly upgrade the module under the steering wheel to accept them.
- Beaker2135
Thanks for the reply. I’ve read the thread but I’ve not had the bumper off yet so I don’t know what’s what and I haven’t been able to find the parts on ETKA yet I bet it’s really obvious if you have both bumpers in front of you
I’m sure we’ll get it sorted eventually a bit like you it’s on my wish list, not at the top but getting nearer
Anyone Got the part number ??
I want to swap a new rear bumper mk3 to mk4
I Got a caddy 2012 short wheel base
Best regards
Henrik
Best regards
Henrik
- RangerD
@ Zak: old post here, but can you help me? Where did you get your mk4 bumper, is it oem? I am looking at Poliplast and the seller is telling me that I have to replace the crash bar as otherwise it'll come up 1cm short to the arches. It is identical to the oem bumper and it's a commonly done mod by folk on here. Did it fit your mk3 crash bar and come up fluxh to the arches, oem style? Thanks
Interested in starting this thread up again. I too would Love a mk4 bumper on a mk3
Something I'm looking to do to once I've got the other jobs completed so going to be a while.
So are we saying you can fit mk3 PDC to mk4 bumper, I haven't had the bumper off yet but thought the mounting brackets for the sensors were just double sided taped into the bumper ?
You can I believe has the holes on the mk4 bumper are 18mm, the correct size for the pdc sensors.
The aftermarket ones that look like 4 small painted spot lights require a 20mm hole and are spring loaded.
