Power Folding Wing Mirror Modules - are mine programmable?
Whitey
Post by Whitey » Sat Mar 31, 2018 12:30 pm
Hi all,
Does anyone know if it's possible to program the following door modules for power folding?
1K0-959-701-MAX3
1K0-959-702-MAX3
Thanks in advance :)
claudiu2s
Post by claudiu2s » Sat Mar 31, 2018 12:39 pm
What are the actual door modules part numbers?
I have genuine VCDS, VagCAN Pro, SMOK and ODIS with online server access for any of your programming needs in Hemel Hempstead/Watford area.
vcds.diagnostic@gmail.com
https://www.facebook.com/pg/VCDSDiagnos ... e_internal
http://vcds-diagnostic.simplesite.com/
Whitey
Re: Power Folding Wing Mirror Modules - are mine programmable?
Post by Whitey » Sat Mar 31, 2018 12:44 pm
Hi Claudius,
Thanks for the reply mate, they are
2K5 959 701 / 2K5 959 702
Did read somewhere I may need a revision 'A' of this module but all i can only seem to find this module on rear door motors :?
claudiu2s
Post by claudiu2s » Sat Mar 31, 2018 12:54 pm
the part number you mentioned above are for mirror motor, u need the part numbers of the module. I am suspecting you have 5K0959793 and 5K0959792 if you have the above motors but i might be wrong. you need to remove the door card and have a look at the part number on the black box (door module). I had exactly the same last weekend and i needed to upgrade the modules to A revision as the one i posted don't have pins for folding mirrors. You will also need folding mirrors as standard one don't have folding motor.
Trevor789
Post by Trevor789 » Sat Mar 31, 2018 12:55 pm
Whitey wrote:Hi Claudius,
What mirrors are you putting on
Whitey
Post by Whitey » Sat Mar 31, 2018 1:05 pm
Thanks for the info claudiu2s, ah i see, was just getting the info from a VCDS scan for parts etc. I will have a proper look, no doubt they will need upgrading haha, i never seem to get lucky!
Hey Trevor789,
I have some power folding life mirrors to go on the caddy, they've been sat here since August :shock:
claudiu2s
Post by claudiu2s » Sat Mar 31, 2018 1:09 pm
I've fitted Caddy life mirrors on Caddyluv last weekend and they didn't work as he had the modules which i told u earlier. We've sourced some A revision ones and will try them tomorrow.
Whitey
Post by Whitey » Sat Mar 31, 2018 1:15 pm
Great stuff, hope it goes well, I will check up on your progress. Did you get the modules brand new or source them second hand? Seem to be quite hard to find!
claudiu2s
Post by claudiu2s » Sat Mar 31, 2018 1:17 pm
second hand as brand new are £289 each
Caddyluv
Post by Caddyluv » Sat Mar 31, 2018 1:22 pm
Fingers crossed for tomorrow 🤞🤞🤞
Whitey
Post by Whitey » Sat Mar 31, 2018 3:45 pm
Looking good Caddyluv - hope it all works out tomorrow for you guys :D
Caddyluv
Post by Caddyluv » Sat Mar 31, 2018 4:37 pm
Let you know.
Whitey
Post by Whitey » Sun Apr 01, 2018 12:06 pm
Cheers mate :D
Trevor789
Post by Trevor789 » Sun Apr 01, 2018 12:19 pm
Whitey wrote:Thanks for the info claudiu2s, ah i see, was just getting the info from a VCDS scan for parts etc. I will have a proper look, no doubt they will need upgrading haha, i never seem to get lucky!
Hey Trevor789,
Do you have a picture of them ?
Trevor789
Post by Trevor789 » Sun Apr 01, 2018 12:26 pm
Trevor789 wrote: Do you have a picture of them ?
Can I ask what are these mirrors off
