Mk4 Xenon Headlights
Haydenwest
Re: Mk4 Xenon Headlights
Post by Haydenwest » Mon Sep 21, 2020 9:35 pm
Do you guys think the xenon headlights upgrade are worth the money?
How easy isit to change on a mk4? Just headlights and coding or isit more than just that?
Thanks.
Post by petrev » Tue Sep 22, 2020 11:06 am
How to thread in section ... Read earlier posts too.
Absolutely brilliant upgrade if done to 35W.
Still better than std. if at 25W factory.
Haydenwest
Post by Haydenwest » Tue Sep 22, 2020 10:37 pm
Thanks for the information guys could anyone link me the parts I need and someone local to Nottingham for coding?
lord-dudester
Post by lord-dudester » Wed Sep 23, 2020 10:23 pm
Em tuning in Wellingborough coded mine
Post by petrev » Wed Sep 23, 2020 10:49 pm
Parts and coding in the How to thread linked earlier in this thread ...
I used OBDEleven for coding.
I posted my parts costs and sources in the How 2.
Caddy46
Post by Caddy46 » Thu Sep 24, 2020 8:15 am
Anyone got a link to the 35w bulbs are they just your standard led bulbs or what? Cheers
Post by petrev » Thu Sep 24, 2020 10:49 am
Xenon
Not LED
D3S
My best prices found last time I searched ...
https://www.lichtex.de/xenon-licht-bren ... 3s-fassung
They also do ballasts and drivers !
Servicon
Post by Servicon » Wed Jan 20, 2021 4:53 am
Anybody got pictures of their conversion with the lights on?
tomislavrast
Post by tomislavrast » Sat Mar 27, 2021 2:27 pm
Any pictures with DRL on?
Thanks in Advance.
BR from Croatia
wildybeast
Post by wildybeast » Sun Mar 28, 2021 10:59 am
Ripley55
Post by Ripley55 » Sun Mar 28, 2021 3:46 pm
That’s a great shot @wildybeast. They make the front look much more cleaner/modern ? 👍
Chestnut Brown Caddy MK4 Maxi Life 2.0Tdi 150bhp , 18” Audi Alloys 8Jx18 ET40 on 245/40/18’s
nik_740
Post by nik_740 » Sun Mar 28, 2021 5:23 pm
So if I get it right, the D3s Xenon lights with 35watt fits in the headlights when there are D8S lights already in it? Or do you need to change the drivers also?
Ripley55
Post by Ripley55 » Sun Mar 28, 2021 6:24 pm
@nik_740
I’m no expert on this, just working to get to Xenon upgrade myself, but I think the 25w "bulb" I prefer to use the word lamp 😂 has a different base flange fitting to the 35w lamp to prevent interchange - I'm told on here it can be fixed DIY by adding a slot in the base flange at the right point, I’m also pretty sure the ballasts will need changing to suit the higher wattage lamp. Perhaps @Giddy or @Petrev can explain in more detail, certainly @Petrev has done this mod
wildybeast
Post by wildybeast » Sun Mar 28, 2021 6:41 pm
You will need 35w ballasts to power the35w bulbs. One bulb per headlight.You then need to put a notch in the new bulb to fit the headlight socket.Then shave a little of the wire plugs at one side that go to bulb and ballast as they are slightly different.I did this carefully using a sharp blade..Part numbers are in the how to section. I stole a couple of pics from the webb .Not from a caddy but might help.ImageImage
tomislavrast
Post by tomislavrast » Sun Mar 28, 2021 9:01 pm
Beautifull pics with DRL wildybeast.
I can't wait for coding.
DRL makes 80% of the attractiveness of the headlight look...
