Hi
I have lowed my maxi about 3 months ago and find i hear a knocking noise, especially under full lock.
I have noticed the current standard front drop links are very close to the bottom wish bone.
Anyone had the same? go for fixed length drop links or adjustable?
Shortened front drop links
- torque777
Re: Shortened front drop links
This is the height of my maxi, been like this for four years now, I changed my front drop links when I fitted coilovers with just febi ones and I've never had any knocking, did you change these and top mounts?
I fitted Hyundai Accent drop links to mine there 50mm shorter,problem solved
