Hi, please could someone help me.
I’ve fitted Touran electric window motors and modules, from a 2006 Touran to a 2005 Caddy. Everything works perfectly apart from the central locking from the remote. It works fine from the button on the drivers door.
Is this a pin problem or coding.
Thanks for any help
Central Locking
- JonesyTDI
Re: Central Locking
Remote central locking is controlled by the central convenience module on this generation of caddy, changing the door control module shouldn't have much affect on the operation.
Do all the doors lock when you turn the key in the driver's door?
Are the interior lights working ok when you open/close the doors?
- JonesyTDI
Re: Central Locking
Thanks for the help Doc.
When I turn off the ignition the interior light comes on and stays on until it goes off with the timer. The drivers door key only locks the drivers door, and the button on the drivers door only locks the front doors.
I used two add a fuse things to pick up lives into the Interior side door clips.
Re: Central Locking
Hi guys I’ve had a similar issue, did touran conversion, motors, doorcards, and extra live for 2011 caddy, my passenger door now doesn’t lock and welcome light doesn’t light up either, changed my door loom and modules and motors to make sure there okay, the windows function correctly and everything works apart from the lock and welcome light, any ideas????
