2016 rear lights upgrade 07 caddy
Re: 2016 rear lights upgrade 07 caddy
I'm going to be doing this soon. Other than ebay is there any other good place to buy a set from? I'm keeping my eyes out for some
59 white SWB 1.9tdi
- dan@biali
They're not that expensive buying from a VW parts dept or TPS if you have a branch that will deal with the public (technically they're trade account only). Should be about £60 each (might be nearer to £70 with VAT).
There are a few other online sellers such as travelin lite who supply to public.
They will need coding if you want to enable the bottom bar and disable the bulb failure warning light.
On 2010 and older Van's you can do it with vcds. Newer van's need the bcm eeprom editing which is a little more involved.
There are also other places like ourselves who supply, fit and code so there are several options.
Bellmans Auto Electronic Services
Specialist vag group electronic engineers based in Sheffield.
We supply and fit cruise control, clusters, new keys, facelift backlights, mfsw etc.
Www.facebook.com/bellmansautoelectronics
Hi Doc,
I don’t know if you remember me but I was the Hermes kid with the ex bg caddy maxi. I’ve finally got myself some 2015+ rear lights and I need some help. I know you mentioned it’s something you do and I was wondering how much it’ll cost?
I’m sorry if I’ve put this in the wrong place, it’s my first post here.
Max
Max
Hi @maxcook30
I charge £30 to fit and code these tail lights.
Drop me an email and we can arrange it for you. Doc at Caddy2k dot com
any 1 got a price on these lights and best place to buy
any 1 got part numbers for smoked lights mk4 at tps please
as when i ring and give them reg of other van not sure if smoked or red lens ?
thanks
thanks
- Giddy
All options are listed in 'useful part numbers' thread
got lights installed got them from travelinlite on black friday deal so cheaper then tps and swapped pins over
just need bottom bar coded
got vag can ordered and will need some instructions to recode once i allowed to view forum
hopefully be all done soon
- Caddy Dan123
@kobra111 hi there looking for info on sidelight location mate as im tapping into wire my side bars in do you know which one i need to use its a mk4 vw caddy 2016 cheers.
Sent from my SM-G998B using Tapatalk
This is my caddy. I really want to upgrade to the 2015+ rear tail lights. I'm led to believe, the barn door model with my tail gate model is a straight swap fitment wise? I also have seen that some coding is required and some wires changed over. once I have adequate posts I may be able to see that. Is that all that is required to swap them over? Is voltage an issue with the LEDs? Thanks for reading.
Repinning and coding is all you need.
The Caddy4 tail lights are not LED so there's no need to worry about that.
Ahh Thanks Doc! I have the lights now all I need is the access to those pins! Haha
@kobra111
Any chance you have the 2008 model colors haha
Reason: removed quote added username tag
So I put my new lights in which I got from the wreckers and I got them to cut the old harness off so I could just follow the colours. Is the coding just to remove the extra reverse bulb? Can I put a resistor in there to solve that issues so I don't have to code it?
