2016 rear lights upgrade 07 caddy
Re: 2016 rear lights upgrade 07 caddy
Hello,
Info is useful, but I want to ask does the lamp holders are the same?
Because I know that those rear lights with coffin corner are different from those we are talking about
Where’s best to pick up a set of these lights?
Probably VW parts desk.
So took a while but wires checked :
My caddy 2013 Pins :
1 - runnig lights
2- empty slot
3- ground
4- brake light
5- Reverse
6 - direction indicator (blinker)
measured on RH lamp EU version so it might me LH lamp UK
1 - runnig lights
2- empty slot
3- ground
4- brake light
5- Reverse
Bulb holder on 2015 checked. RH lamp :
1- ground
2- Reverse
3- running lights
4 - empty slot
5- Direction signal (blinker)
6 - brake light
As Ive mentioned it is RH lamp on EU model so no fog lamp so far and should be LH to UK models.
I have ordered RH comlet lamp and will try to fit it next week. Will let you now new info then
1- ground
2- Reverse
3- running lights
4 - empty slot
6 - brake light
Sorry I had wrong bulb holder checked - one door 2015+
You will need doube door 2015+ here it is :
1 - Ground - brown
2 - Brake - red or black/red
3 - direction - black/green or black/white
4 - lights - grey /red or grey /black
5- Empty
6- Reverse
I did replace last night and the only thing you need to change in ECU is fact , that older caddy has double reverse lights
1 - Ground - brown
5- Empty
6- Reverse
The easiest way to do the bulb warning light at home could possible just buy a simple 21w bulb holder and hide it somewhere in luggage under trim
safely to do not burn something (reverse light does not work for long usually so might not be a big problem)
Done the same to mine still need to figure coding out waiting to see thread
- DC10CAD
I would like to fit the new oem lights to caddy maxi i know about repinning them but im told you need a resistor to bypass secondary reverse light as new version has one not two can someone please guide me
Have a look at the how-to, it's got all the guidance you need.
- anoneamus
What Doc said. I don't think there is much value in trying to get technical info out of this site without participating enough to get your post count up. Everything you need to know about this is in the "How to" post. Post some pictures of your van. Respond to some questions if you can answer them. 10 posts (or whatever it is) isn't much to do and faffing around without info when it's all available is a waste of time...
i will need this done soon. They look great
Guys, just follow the rules of the forum, it doesnt take long to get your post count up and get full access. Its well worth it for the how to's alone, there are some very helpfull, knowledgable people running the forum, All your answers are here,IF you follow the rules.
Livin the maxi life!
Just wired them in. Thats not that hard to do, only the coding needs to be done now.
