Caddy mk4 build
Michele
Re: Caddy mk4 build
Post by Michele » Thu Apr 04, 2019 7:09 am
Image test fitted my S5 Rotors super concave version not bad at all Image
r1lea
Caddy mk4 build
Post by r1lea » Thu Apr 04, 2019 8:16 am
Aren’t genuine S5 rotas 9j et33 ?
How would they fit a caddy mate ?
Does your side door open ?
Did you replace your ballasts and get your headlights working
Michele
Re: Caddy mk4 build
Post by Michele » Thu Apr 04, 2019 8:41 pm
R1lea yes there oem S5 rotors 9j et33 buth the side door won’t open with this set up
And funny story about ballast they send me again the wrong ballast so now i have 4 wrong ballast at home ..
Lawrenceland
Re: Caddy mk4 build
Post by Lawrenceland » Sat Apr 06, 2019 2:15 pm
Nice wheels, what size are they ? I have just started my mk4 build and keeping myself awake wondering what wheels to get !!! Like 19” but not so keen on 35 profile tyres so probably 18 Pretoria style I’m thinking.
Looking to see what else you do to yours 👍
Michele
Re: Caddy mk4 build
Post by Michele » Tue Apr 09, 2019 7:51 pm
Lawrenceland there 19 inch 9 J ET 33 with hankook tyres 225/35/19 Image these are mine 18 inch 8v rotors 7,5J et51 continetal tyres 225/40/18
Lawrenceland
Re: Caddy mk4 build
Post by Lawrenceland » Wed Apr 10, 2019 10:35 pm
Lovely looking van, I do like them in white but that’s probably because mine is !!!!!
Just took the plunge and ordered some 19” Rs4 c reps.
Being delivered tomorrow and fitted on Friday along with the lowering kit 😁
Looking forward to Friday!!!!
Just to find a sat nav next. Project caddy 👍
Michele
Re: Caddy mk4 build
Post by Michele » Sat Apr 13, 2019 12:34 pm
Nice
Michele
Re: Caddy mk4 build
Post by Michele » Wed Apr 17, 2019 3:59 pm
ImageImage i think im gonna lowered it Image oké kw suspension here we come
Michele
Re: Caddy mk4 build
Post by Michele » Fri Apr 19, 2019 10:44 am
@R1lea and @stan_the_man
They finally work on my caddy thanks for all the with coding and workingout what was the problem ImageImage
r1lea
Re: Caddy mk4 build
Post by r1lea » Fri Apr 19, 2019 5:04 pm
stan-the-man
Re: Caddy mk4 build
Post by stan-the-man » Fri Apr 19, 2019 5:24 pm
Glad is all sorted buddy
Dayoster
Re: Caddy mk4 build
Post by Dayoster » Thu Mar 12, 2020 8:33 am
How easy do the bumpers come off on the mk4?
Over worked and underpaid!
Dayoster
Re: Caddy mk4 build
Post by Dayoster » Sun Mar 15, 2020 12:56 pm
Installed and my drls seem dim compared to these photos on here?
Iv checked the DRL dimming byte and its set to 100. Does that mean 100%? Or can it be increased?
Also, how to disable xenon for coming home/leaving home lights and to enable fogs? So drl and fog are active without xenon?
Many thanks
r1lea
Caddy mk4 build
Post by r1lea » Sun Mar 15, 2020 3:34 pm
92% is max brightness
Have you coded them correctly as DRLS ?
DRLS should be on with switch in the 0 position and will usually dim in other switch positions
Also look at parking light dimming
There is a byte for having fogs as ch lights, that will stop the xenons
I think it’s later on in the byte numbers
Dayoster
Re: Caddy mk4 build
Post by Dayoster » Sun Mar 15, 2020 7:27 pm
Yes the drls are on on their own when turned to 0.
As for the brightness, do i change the 100 figure to 92 for max brightness?
