Page 1 of 2
Lowering question
Posted: Thu Apr 25, 2019 1:07 pm
by Waltdog
How much should I have my caddy lowered on 225/40/18’s? Has anyone got photos of 40mm vs 60mm etc? Thanks in advance
Re: Lowering question
Posted: Thu Apr 25, 2019 2:19 pm
by Caddyluv
You can go quite low buddy. Set what you think. Drive round the block so the suspension settles a bit. Check again. It only takes a few mins to raise or lower it if your using a ramp.
Posted: Fri Apr 26, 2019 8:17 pm
by Waltdog
Thanks for the reply. I’m gunna go with 60mm to start
Posted: Fri Apr 26, 2019 9:53 pm
by Skully
My Maxi running 225/40/18 and lowered 60mm in front and 70mm rear (JOM coilover + axle flip kit) :
Posted: Fri Apr 26, 2019 10:05 pm
by Waltdog
Very nice
Posted: Fri Apr 26, 2019 11:38 pm
by Pete M
Would the same be ok on a 2009 model?
Posted: Sat Apr 27, 2019 11:02 am
by threepeaks
lowered on 60mm H&R springs and axle flip kit. Handles much better especially the wallowing on the motorway in strong winds. £500 all in Total cost. Well Chuffed. Also Running 225/40/18's
Posted: Sat Apr 27, 2019 6:02 pm
by Waltdog
Looks smart that,I’ll get some photos of mine up once it’s done
Posted: Mon Jun 10, 2019 7:37 am
by RobbieCT
Skully wrote:My Maxi running 225/40/18 and lowered 60mm in front and 70mm rear (JOM coilover + axle flip kit) :
sorry for the post hijack. This pic isn't in Skullys build thread. Skully did you have the roof sprayed or is that also vinyl like the side panels I've been thinking of doing the same to mine.
Sent from my EML-L09 using Tapatalk
Posted: Mon Jun 10, 2019 7:45 pm
by Skully
I will update my ride thread sometime soon.
It is vinyl.
Posted: Mon Feb 24, 2020 6:27 am
by Jones
Skully wrote: ↑Fri Apr 26, 2019 9:53 pm
Hi Skully,
The van is looking sweet!
May I know where did you manage to get your flip kit in SA from?
Posted: Mon Feb 24, 2020 11:43 am
by Skully
Jones wrote: ↑Mon Feb 24, 2020 6:27 am
Hi Skully,
Thanks.
Got it from IS Motorsport. They are JOM agents here in SA.
Posted: Mon Feb 24, 2020 12:44 pm
by Jones
Thanks, much appreciated
Posted: Sun Mar 01, 2020 11:47 am
by Conrad
Skully wrote: ↑Mon Feb 24, 2020 11:43 am
Thanks.
Nice ride @Skully, the black looks great, I do get jealous of the two tone multivans around the place. Does it get hotter in the sun? Mine has gone the other way with a suspension lift and now looking for tall A/T tyres. Just a quick question about the axle flip, I know that it lowers the car it does it also give you more Axle clearance (other than where the springs bolt on)?
Will post some pics when I work out how!
Posted: Sun Mar 01, 2020 5:10 pm
by Barrington
Hi all
Would lowering an ex British gas be harder due to the rear end being higher than a standard caddy.
