Asz engine transplant
gjseb
Re: Asz engine transplant
Post by gjseb » Fri Jul 12, 2019 2:39 pm
Just gauging pros and cons so basically you doing it for strength and not speed if you keep the bls parts then so it will be running same horse power as before
Cheers Gordon
Novakid
Post by Novakid » Fri Jul 12, 2019 3:22 pm
Mine has been mapped to 140 anyway so would not gane anything. More reliable the asz.
Super64
Post by Super64 » Wed Feb 19, 2020 8:46 pm
Seeing as the BLS oil cooler/filter housing is smaller that the ASZ n won’t bolt on does anybody know if the cooler section can be separated & swapped to save having to make joints in the coolant pipes? On another note does anybody make a plug/bung to blank the ASZ crank sensor, rather than having the old sensor flapping about.
Adie66
Post by Adie66 » Thu Feb 20, 2020 2:07 pm
Just leave it plugged into the engine heat shrink the plug an tie it up out of the way what i did with mine pal
Super64
Post by Super64 » Thu Feb 20, 2020 6:33 pm
I did think that.... and then my ocd mind stuck its nose in. 🤬
Adie66
Post by Adie66 » Wed Mar 04, 2020 12:26 pm
Haha yeah but out of sight out of mind
Super64
Post by Super64 » Wed Mar 04, 2020 9:38 pm
Think that’s the only option. I’ll do battle with my mind n see who wins. 😂
Super64
Post by Super64 » Fri Oct 16, 2020 9:13 pm
Regarding the crank sensor. Rather than leave it in, a 13/16” core plug fits perfect. Bit of RTV & knock it home like you would any normal core plug. Maybe make a cover from a sheet a 5mm aluminium for extra security. 👍
