Hi all, I’m wondering if anyone can throw any light on this. There’s a little pool of water under the van. I’ve had the A/C on today and this has happened once before. (though I can’t remember if I used the A/C on that occasion) I’ve monitored the water level in the header tank and the level isn’t dropping.
I know A/C produces condensation, does that sound like a likely cause?
Thanks lads
Bit of a water leak.
Re: Bit of a water leak.
Certainly does happens all time on our golf if we have air con on mate
If you've had the A/C on there is probably moisture condensing on the evaporator which should drain via a pipe to the exhaust tunnel just below the dash.
Sometimes the Evaporator can form ice and this only melts after you park up this dropping a fair amount of water onto the ground.
Thanks for the advice guys. I’ll keep my eye on it just to make sure
High chance it is the AC, mine puts out quite a bit of water on the driveway from it.
Having kept an eye on the header tank level over the last few days, it has remained constant. I’ve done a 160 mile drive in that time, so all looks well. Thanks gents
