BLUE R needles on clocks
- sheepy92
Evening all could someone point me in the right direction on how to go about changing my red needles to the blue ones like those on an R spec
Re: BLUE R needles on clocks
I’ve got blue needles in mine. Not too sure on how it’s been done as I only got it yesterday.
I’m sure he said they were golf gtd dials
To change to red needles to blue you need to source a set of blue needles and the necessary LEDs.
You then need to remove the needles and red LEDs and replace with blue.
Not a simple task unless you have the necessary tools. @Tommyzooom did his in green a few years ago.
A GTD instrument cluster has red needles and a red band around the outside of the large scales, fitting blue needles on them just looks a bit odd to me.
make sure to turn the dial needles anticlockwise to remove them
I've never ever turned the needles to remove them, neither clockwise nor anti clockwise.
I have replaced stepper motors for people who have done tried the twist off method and blown the motor to bits.
Doc did you ever manage to refit the needles so they “twitch” on ignition on? Hope that makes sense? I noticed that after removing them they don’t seem to do it after refitting. Just curious
Yes, the stepper motors fall back to a position just slightly below where they start when ignition is turned on.
Any advice on where to pick up some needles and a new speedo display?
There used to be a guy from Slovakia selling original blue needles on eBay, I've not looked for a while.
What wrong with your display? I'd suggest a full cluster swap rather than just fitting a display, there are a few different types that look the same. I don't think you'll often find the display for sale seperate to a full cluster anyway.
I just wanted to change it so I could have a digital speedo also, as at present I’m unable to do so and it comes up with cruise control in KM/h not MP/hDoc wrote: ↑Mon Mar 02, 2020 7:24 am There used to be a guy from Slovakia selling original blue needles on eBay, I've not looked for a while.
A new display won't fix that, it sounds like someone has messed up your coding.
You'd need to post a scan showing your part number and coding for anyone to work out what's wrong.
This sounds like it’s going to be a tricky job, thanks Doc see what I can conjure up!
