Whine from steering wheel
Chrispope26197
Post by Chrispope26197 » Fri Sep 06, 2019 3:27 pm
Hi guys, I’ve just noticed my van has a squeaking/whining sounds when I turn the steering wheel!? Any idea what this is? If it’s bad or not lol?
Re: Whine from steering wheel
Post by Doc » Fri Sep 06, 2019 3:32 pm
Is it a groaning sound coming from the front suspension? That'll be top mounts.
Chrispope26197
Post by Chrispope26197 » Fri Sep 06, 2019 3:42 pm
Sounds like it’s from the steering wheel. I had new top mounts 2 months ago when coilovers went on
Post by Doc » Fri Sep 06, 2019 3:46 pm
Is it a scratching/scraping noise like the wheel or slipring rubbing on the cowling?
Chrispope26197
Post by Chrispope26197 » Fri Sep 06, 2019 3:57 pm
No it’s like a whine/ squeak more than anything
Chrispope26197
Post by Chrispope26197 » Fri Sep 06, 2019 4:05 pm
It’s only when you are slightly wobbling the steering wheel quickly left and right
Darylg21
Post by Darylg21 » Wed Sep 11, 2019 12:10 am
Is it inside the van or in the engine bay?? Is it on full lock??
I treated a 1 series with a very similar sounding issue the other week, Hers was under the dash, a simple removeval of rubber and coverings from the steering stalk spray with a ptfe lube (wd40 type will do) and all sqeaking gone.
Chrispope26197
Post by Chrispope26197 » Wed Sep 11, 2019 4:03 pm
Yeah it’s inside the van and only when turning the wheel very minimal but quickly.
Darylg21
Post by Darylg21 » Wed Sep 11, 2019 6:32 pm
There is a video on the tube of a guy fixing a 3series bmw. Soumds luke the issue you are having. Basically get under the dash and lube up that shaft..............
