Perspex Bulkhead Covers
- Crs_b
Is anyone making the Perspex bulkhead covers that Tommyzoom used to make? I’m after some tinted ones.
I can’t seem to find any anywhere, next option is to make some.
2008 - VW Caddy - 1.9Tdi - The Daily
1991 - Mercedes 190e - 2.6 - Show car project
1991 - VW Mk2 Golf - 1.8T - Race car project
2006 - VW Passat - 1.9tdi - Breaking for spares
Re: Perspex Bulkhead Covers
Made my own after contacting tommyzoom and finding out he no longer makes these,there very simple to make I had the two made and fitted in less than an hour
Woah. Explain? What are these things?
06 sdi caddy2k :: 81 Transporter T3 :: 2015 Golf 1.4 TSI :: Freelander (sorry)
Herefordshire and all over.
- Vwjack88
Where did you get the perspex from mate?sbyrne2012 wrote: ↑Tue Mar 10, 2020 11:22 pm Made my own after contacting tommyzoom and finding out he no longer makes these,there very simple to make I had the two made and fitted in less than an hour
- Bigg83
B&q do perspex sheets i have got them from there before for projects in the past
Sent from my SM-N960F using Tapatalk
- gazza31112
B&Q and Wickes do it mateVwjack88 wrote: Where did you get the perspex from mate?
Any diy store will have it,I also used some window rubber around the edge of the Perspex just to finish it off nicely
- Vwjack88
I've never brought perspex before, will they have pieces roughly the size I need or will it be a massive sheet I have to buy?
Will pop over b&q the weekend
- gazza31112
@Vwjack88 hi mate, I find with b&q it's a bit hit and miss, it will be in the builders section in a big rack, all depends on stock levels, but they do sell different sizes, I think I used to buy 1200x600
- Vwjack88
Cheers brother, you reckon wickes would be a better choice then
- gazza31112
I tend to remember Wickes is cheaper, not brought it in ages, anything over 2mm thick starts getting expensive
Ya I used one sheet of 1200x600 worked a treat was just the right size and not too much waste
