Headlight Conversion
Re: Headlight Conversion
Post by Doc » Tue Mar 24, 2020 8:12 pm
Low beam is the headlamp bulb operating in the "dipped" position.
What you have photographed is the light switch in the sidelight position.
Post by gazza31112 » Tue Mar 24, 2020 8:12 pm
That should just be the DRL's? Low beam is the dipped headlight?
Post by gazza31112 » Tue Mar 24, 2020 8:13 pm
My bad, sidelights
Post by gazza31112 » Tue Mar 24, 2020 8:15 pm
My DRL's/sidelights are on when switch is set to the first "off" position
kully12
Post by kully12 » Tue Mar 24, 2020 8:18 pm
EDITED to correct terminology
Please have a look at my updated/edited post above, more so about what the drls do when you turn on the fog lights
Post by Doc » Tue Mar 24, 2020 8:19 pm
For your headlight switch.
O= DRL only
AUTO= Automatic switching from DRL during daylight to low/high beam with sidelight (DRL off) in darkness.
(> <) = Side lights (DRL off)
€> = low/high beam with side lights (DRL off)
Sorry about the symbols, it's the closest I can make to those on the switch using text.
Post by gazza31112 » Tue Mar 24, 2020 8:20 pm
I'm amazed you got the symbols that close lol!
Post by Doc » Tue Mar 24, 2020 8:22 pm
I grew up in an era of text messages restricted to 160 characters and no emojis.
Giddy
Post by Giddy » Tue Mar 24, 2020 8:23 pm
DRL/Sidelight is a 21W/5W bulb, two in one.
0 = DRL on (21 W), everything else off.
Auto = DRL Off, Sidelights on (5 W), Dipped lights on
Sidelights = Sidelights on, DRL off, Dipped lights off
Dipped = Dipped lights on, Sidelights on (5W), DRL off
p.s. Doc posted the almost the same above
Rossy888
Post by Rossy888 » Tue Mar 24, 2020 11:15 pm
Doc wrote:I grew up in an era of text messages restricted to 160 characters and no emojis.
So true ImageImage i forgot about them days till now Image
Strath25
Post by Strath25 » Sat Mar 28, 2020 7:01 am
Loving my headlights...Image
Post by Doc » Sat Mar 28, 2020 7:49 am
Are yours working ok or have you the same fault with DLR/side light function?
Strath25
Post by Strath25 » Sat Mar 28, 2020 8:34 am
Doc wrote:Are yours working ok or have you the same fault with DLR/side light function?
With low beam the DRL is on but the dimmer version (ie sidelight) and not full blown bright DRL
Giddy
Post by Giddy » Sat Mar 28, 2020 8:39 am
Don't know what's the internal wiring of the headlight, but should be relatively easy fix.
kully12
Post by kully12 » Sat Mar 28, 2020 9:26 am
Strath25 wrote: With low beam the DRL is on but the dimmer version (ie sidelight) and not full blown bright DRL
@Doc previously did you say this was normal or you think this is a fault?
