Lowering kit suggestions?
rush roo
Post by rush roo » Sat Oct 26, 2019 8:18 pm
Guys any advise for a good lowering kit ?
sheepy92
Re: Lower?
Post by sheepy92 » Sat Oct 26, 2019 8:20 pm
Stx lowering kit drop it on its arse lad top notch on the leaf lowers low n slow
rush roo
Re: Lower?
Post by rush roo » Sat Oct 26, 2019 8:26 pm
Thanks mate I will look it up, comfortable though?
sheepy92
Re: Lowering kit suggestions?
Post by sheepy92 » Sat Oct 26, 2019 8:27 pm
Coilovers on front and shackle kit on back with new shocks theyre made by kw so good quality id say most value per sobbs
rush roo
Post by rush roo » Sat Oct 26, 2019 8:30 pm
wicked i will look more in to them cheers pal
Re: Lower?
Post by the swan fiend » Sat Oct 26, 2019 8:32 pm
Hi mate, welcome to the forum. It all depends what you want to spend really. If you’re looking at the bottom end of the market, I’d say Stance, or anything you see around the £250 mark. Mid range, VMaxx, JOM, AP, ST. Moving up, Bilstien, BC racing, KW. If you really wanna splash out, get an air ride set up. The world is your lobster mate!
If you just want lowering springs, check out eibach or H&R for the front, and a shackle kit on the rear.
Shop around too....Darkside developments, Awesome GTI, Demon Tweeks to name a few! Have fun researching mate
Post by the swan fiend » Sat Oct 26, 2019 8:33 pm
I’m using the ST kit by the way......gets my vote!!
BillyGilly
Post by BillyGilly » Sat Oct 26, 2019 10:16 pm
I fitted 60mm Eibach springs on mine. Very happy with them.
rush roo
Post by rush roo » Sat Oct 26, 2019 11:55 pm
Cheers bud will look at these too
M3rosco
Post by M3rosco » Sun Oct 27, 2019 3:27 pm
There are so many variables. Mainly down to budget and usage.
Budget coilover suspension will give the look you want, but will ride like crap in comparison to KW or Bilstein. ST is a good mid range product. Made by KW too.
rush roo
Post by rush roo » Sun Oct 27, 2019 8:07 pm
Cheers mate its looking like either kw or st now you might have just made my decision a little easier
Carpy247
Post by Carpy247 » Fri Nov 01, 2019 10:36 pm
Hi pal i've got a KW rear axle flip kit in for sale section if your interested.
Sent from my Pixel 2 using Tapatalk
lord-dudester
Post by lord-dudester » Fri Nov 01, 2019 10:59 pm
I went top end and went for the h&r deeps from stillstatic. Not the cheapest. But rides superb and they let you go really low if you’ve the balls for it
rush roo
Post by rush roo » Mon Nov 04, 2019 7:01 pm
Thanks mate I think I’m going to hold off from getting anything yet whilst I get some other things done, if I can get in to the sale section I will take a look.
rush roo
Post by rush roo » Mon Nov 04, 2019 7:05 pm
Ah yeah I’ve seen yours, looks wicked I will keep that in mind. Btw dude I’ve got those xenons 🙌🏾 I’m going try and open them up and spray the inners gloss black like you did, shouldn’t be too hard😬.
