Hey all,
Am looking for some 19” alloys for my 2018 caddy, but I don’t want them to wide to where I can’t open the side door. So what diameter wheel would I need?
Many thanks
Jake
Caddy alloys
Re: Caddy alloys
Cant comment on exactly what fits but the offset of the wheels will also affect how much they stick out as well as the width
Re: Caddy alloys
Hi mate. Use a website called willtheyfit.com. Input your wheel information into that and what wheels you’d like to buy and it’ll tell you how far they’ll stick out, speedo accuracy etc. It won’t tell you about the sliding door, but you should be able to work that out once you have the info
Study your standard wheel specs first though. All measurements and variables are important!
- Savaloy
Re: Caddy alloys
I have a set of VW alloys which are 19x8.5 with a ET 41 that fit beautifully if that helps dude?
I also run the caddy quite low as well and I have no rubbing and still can have a fair bit of weight in the back tools etc
