Upgrade steering wheel for Mk4
- Savaloy
Hi all,
I’ve been thinking about swapping out the steering wheel with the golf R steering wheel with the controls.
What would be the process behind the swap? Is it a plug and play unit or is coding and wiring modification involved?
Many thanks
Ben
Many thanks
Ben
- RKDesigns
Depends which caddy you have and which options. Polo and scirocco is plug and play. Golf can be different and coding will be nessesary in that case if cruise buttons are on the steeringwheel for example.
If you want to swap the parts as well with the handles and slipring you have to code if it even would start to work in the end. Perhaps you need more to change in that case.
I have a trendline, was with mfsteeringwheel from factory, polo R line steeringwheel works directly besides the cruise buttons on the left. Still use the handle. Can change it from the handle to the buttons with getting it coded.
- Savaloy
Re: Upgrade steering wheel for Mk4
Thanks for the reply dude,
I have a 2015 2.0 TDI caddy if that helps any, it has cruise control and also a kenwood aftermarket DAB radio so would I be able to use the steering wheel controls with these or would coding be needed?
- r1lea
A mk7 golf R wheel with cruise on the buttons will not work without an additional aftermarket module, there’s a member on here ( spacewalker ) that makes and sells them
Then you’d need to replace the indicator stalk for a plain non cruise stalk
To get an aftermarket stereo working you’d need the relevant controller no matter what steering wheel you went for
Connects2 sell the modules for aftermarket stereos
- RKDesigns
@Savaloy, mine is a mk4 10-2015 2.0 CR euro5 140hp with custom remapping. More powerful than the euro6 150hp custom remapped.
Be aware that fully loaded Golf 7 models are with different modules and bmc! Like in the previous post has been written a spacewalker module will be needed to get it the easiest way working.
A mate knows how to get it working but he does it on a daily base here in the Netherlands, but he will not tell others how he does it. He earns his money with this kind of mods.
- Savaloy
Sounds like you have the same van as me mateyRKDesigns wrote:@Savaloy, mine is a mk4 10-2015 2.0 CR euro5 140hp with custom remapping. More powerful than the euro6 150hp custom remapped.
Thank you for that gents I’ll have a little look for the module that controls the stereo.
Just wondering though is it essential that a non cruise control stork is required?
Thanks for the replies fellas
- r1lea
There penny’s mate, and easy to swap whilst the wheel etc is off
Here’s my mk7 wheel, fully functional with the spacewalker module
- Savaloy
That looks awesome, it’s certainly something I’m going to be looking forward to having.
I just need to start gathering parts now
- RKDesigns
Here is mine
- RKDesigns
Have got this one, but as well the buttons can be changed. Two are half loose in my case so found others.
- Savaloy
- Josh764
Absolutely love the look of that mk7 wheel, definitely something I'd like to do to my caddy, love those seats to, coming from a complete novice are seats and easy swap?r1lea wrote:There penny’s mate, and easy to swap whilst the wheel etc is off
- r1lea
The wheel offset looks spot on RK
- RKDesigns
Will make some photos tomorrow, can’t find between the 26.000 photos on my phone so fast a photo of my interior. So thought a that lawnmower has a steeringwheel as well hahaha (got exported to Poland in the meantime).
@r1lea the cruise on the handle still works as well in your case? I know if mine gets cruise working on the buttons it’s not working anymore via the handle. Or you changed in your caddy the handle?
- r1lea
Rk, to get cruise working on the wheel, it goes through the spacewalker module and bypasses the oem steering module
No the cruise on the stalk will no longer work after
I’ve changed my stalks to the mk7 golf stalks
