BANG! My engine just exploded...
Cultus
Re: BANG! My engine just exploded...
Post by Cultus » Sun Jan 05, 2020 5:27 pm
Well done, do you have a picture of the new asz engine in the bay?
Did you get the asz engine swapped in with the injectors and turbo or did you keep the Vans original bls turbo and injectors?
Frampers
Post by Frampers » Mon Jan 06, 2020 8:57 pm
Thanks, I will upload a photo tomorrow
It is running the original BLS turbo and injectors
Peli
Post by Peli » Mon Jan 06, 2020 9:53 pm
For my van the EGR is also codes but i have the EGR still on the engine. I only have a closed sail so i'm sure the EGR is not working.
Taylor26
Post by Taylor26 » Tue Jan 07, 2020 8:51 pm
This happened to my van as well :shock: I am mid way through doing a asz swap but I am retaining the 130 injectors but have changed to a 150 turbo but if you go this route you will have to get a custom remap straight away
Frampers
Post by Frampers » Wed Jan 08, 2020 9:22 pm
As requested, heres how its looking currently:
Nathan107578
Post by Nathan107578 » Fri Jan 10, 2020 8:35 pm
Hey dude . How much did the new engine cost fitted ?
Cultus
Post by Cultus » Sun Jan 12, 2020 12:15 pm
Looking good, just watch out for where your pipes are cable tied together as they will move and rub as the engine runs and start to wear each other out ,
you could get some leaks, best but a little rubber or something between them then strap them together, it will save you getting stuck on the side of the road down the line !
