1.8 20v turbo ?
1.8 20v turbo ?
Question gents can the mk4 golf gti turbo be fitted in the caddy bay and what gearbox would you use also concerned about the curling and the dash as lots of canbus on the caddy cheers
I come here for R&R
Re: 1.8 20v turbo ?
Hi mate
The mk4 gti engine can be fitted but depending on what engine code it is, as the older mk4 engines are cable throttles not DBW.
I have ran a 1.8t on my caddy, would i run one again....no lol IMO now there are so many better swaps to be done, As where the 1.8t engines are getting on a bit now. But if you do go for one, i used a o2j 5 speed box on mine with the caddy 5 speed shafts. it all pretty much bolts in. You will lose things like Cruise control as how the caddy one works is totally different to the mk4 platform type. Drop me a message if you need any more info and i will try my best to answer.
Re: 1.8 20v turbo ?
https://ibb.co/RC6LD24
Been putting mine back together tonight Got the 6 speed started as a 225 bam before I blew it up coming back stronger though
Itβs fairly easy to do but if you need a hand give me a message !
Re: 1.8 20v turbo ?
Many thanksBB13 wrote: βMon Nov 11, 2019 5:16 pm Hi mate
I come here for R&R
Re: 1.8 20v turbo ?
Cheers mateShropy wrote: βTue Nov 12, 2019 10:28 pm https://ibb.co/RC6LD24
I come here for R&R
