Hello! New here
I switched from the caddy seats today, and switched to Audi A4 2012 S-line seats. I would like some help with the wiring to the heated seats.
Its three wires from the A4 seat and the plug from the caddy does not match. So i need som help from u guys maybe a diagram or some pictures with the right wiring and colours. I tried wiring it up myself, but the heat in both seats are on all the time the original switch wont work..
Thanks in advance!
Heated Seats Caddy 2012
- tommyzooom
Re: Heated Seats Caddy 2012
Was your original Caddy seats heated ?
Yes they both were heated, and both had 3 steps on the button on the A/C controller
Oh I see!
Ok the above drivers seat...
Audi: Caddy:
green/brown to pin 2 (black)
black/white to pin 3 (brown)
brown to pin 3 (brown)
red/white to pin 4 (brown/yellow)
Stan The Man said this, can this be the right way to wire it up?
Audi: Caddy:
- tommyzooom
Your Caddy passenger seat will have a heated saet control module under it, to control both seats.
The Audi seats dont have this, as the module is incorporated into the dash controls in an Audi.
You will need to swap the module over to control the Audi seats.
Post some pictures of the audi seat plugs, and the plugs in your van. An adapter could be made up.
Ok, will get some pictures tomorrow thanks!
