Indicators and wipers working on and off
As above guys any ideas they seem to work on and off it becoming a pain and it can't just be stalk as when wipers don't work indicator don't work either
- maxx007at
Re: Indicators and wipers working on and off
I’d start with connecting a diagnostic tool and see what errors are stored in address 16 (SWCM)
Mine go on and off too....
Will get it plugged in tonight had to happen when had the worst rain in like 5 years lol
- brooneye
My wipers were intermittent like that and after a diagnostic showing nothing I set a bout tracing the wiring and it turned out to be a badly chafed wire
Where did you trace wire back too was there a certain point it was chafing
- brooneye
It was quite a way back, the wire was only working off a few strands and this was causing them to come and go intermittently
Coming up with fault on terminal 15 any one got any ideas
- r1lea
Terminal 15 = Switched power, live when the ignition is on
Terminal 30 = Unswitched power, always live
Terminal 31 = Ground
Due to your issue and it’s location, I’d be looking at the ignition switch first
Right had a auto electric guy out today and he has told me my bcem is what has failed is this common or as any one heard off this
Head lights full beam won't click on now either I can flash but not stay on, some else as also told me it could be to do with the cheap hid kit I put in it
What build year is you caddy?
