Power loss
James01
Re: Power loss
Post by James01 » Thu Nov 21, 2019 10:26 pm
Could it be worth putting the standard wheels on for a tank of fuel just to make sure it's not that. Then go back to the dealer
MarkMcQ
Re: Power loss
Post by MarkMcQ » Sat Nov 23, 2019 5:36 pm
This may sound a really naive question but could the adblue be affecting it? Is there different grades of adblue? I know it’s only water and urea mixed but not sure about it!
Giddy
Re: Power loss
Post by Giddy » Sat Nov 23, 2019 7:16 pm
Wide wheel do affect fuel consumption, especially heavy ones, but won't be that much like in your case. Also could be your driving pattern, if you do alot of short trips. Could be combination of both of these factors. These engines take forever to heat up to the full temperature. I had a brand new van with same engine for a day, while mine was serviced. Took about three times longer to heat up, than my petrol engine on the same run. If I had a diesel, I would be running cold engine for most part of my 7 miles journey to work.
Caddy 4, Highline, 1.4 TSI
Build thread https://www.caddy2k.com/forum/viewtopic ... 13&t=37368
MarkMcQ
Re: Power loss
Post by MarkMcQ » Sun Nov 24, 2019 6:21 am
The mileage was recorded over 3 separate motorway journeys of 330 miles each (165 each way from home to work) I live 1 mile from the motorway. There is no gear change for at least 154 miles and a constant speed of 70mph. I let the cruise control do the accelerating so I would say the driving style is very conservative. No hard accelerating!
MarkMcQ
Re: Power loss
Post by MarkMcQ » Wed Nov 27, 2019 4:03 pm
Ok. Because of time constraints. I’ve got it booked on to a rolling road to tell me true power output but can’t get it done till 21st December. To me there is a definite power loss so I guess this will tell me if I’m write won’t it?
MarkMcQ
Re: Power loss
Post by MarkMcQ » Thu Nov 28, 2019 12:39 pm
MarkMcQ
Re: Power loss
Post by MarkMcQ » Thu Nov 28, 2019 12:41 pm
