Steering Wheel Paddles
Can someone please tell me the part no for steering wheel with paddles for 2019 caddy 2.0 tdi dsg 150hp with cruise control ??
Thanks in advance
Thanks in advance
Re: Steering Wheel Paddles
Subscribed
I am looking for the same for my 65 plate
I have brand new one for sale with grey stitching
Is there much involved in fitting it ? will it need coding ? and the most important question how much
Anybody ??
I fitted 1 to my 2018 caddy dsg straight swap no coding required dsg paddles worked perfectly straight away, hope this helps
Instagram @berger2k
If you don’t have multifunction you need to code it in as you need to change existing skirting as well. If you already have multifunction should be straight swap
Thanks stan I would like to buy the wheel you have. I see that you are in Clare I'm also in Clare.stan-the-man wrote: ↑Tue Nov 26, 2019 1:15 pmIf you don’t have multifunction you need to code it in as you need to change existing skirting as well. If you already have multifunction should be straight swap
No not yet
What part of Clare are you in ?
I’m just outside Barefield
. You can email me at stachur32@gmail.com
Email sent
Met up with Stan today to buy steering wheel and he actually installed for me and did some coding tweaks as well. Great to know there are still decent people out there it restores the faith. An absolute gentleman thanks again
