Had the van serviced today at a VW/AUDI centre. Great bloke who appears to know his stuff.
I asked if he'd be able to code the rear lights and he said yeah, no problem
When I returned to pick the van up, he'd done a full VCDS scan of the van and said there was no option to code out the rear right reverse light (which is the issue)
He said he'd put a resistor in to remove the fault.
I've left it as is for now. Any advice is, as always much appreciated.
Coding Rear Lights Query
- DeanWhit
Re: Coding Rear Lights Query
A resistor isn't the best solution.
Have a look at the how-to guide for information on removing the error without risking damage to your van.
- DeanWhit
Spent a while mulling it over and looking through different threads and I think I'm just going to book in with you after Christmas and let you look at it if that's ok.
Its also a good excuse to stretch the vans legs so to speak haha.
Ok, sounds good.
Im having the same problem, put facelift rear lights onto my 2006 caddy today and the check bulb light is up on the dash. Its a shame its not as simple as a restore install
your 2006 can be coded with VCDS very easy, only takes 2 minutesYlmperformance wrote: ↑Mon Dec 02, 2019 11:06 pm Im having the same problem, put facelift rear lights onto my 2006 caddy today and the check bulb light is up on the dash. Its a shame its not as simple as a restore install
I have genuine VCDS, VagCAN Pro, SMOK and ODIS with online server access for any of your programming needs in Hemel Hempstead/Watford area.
vcds.diagnostic@gmail.com
https://www.facebook.com/pg/VCDSDiagnos ... e_internal
http://vcds-diagnostic.simplesite.com/
ItS very easy, did my own with OBDeleven, I think the settings you need to change are in byt3 and byt9 if I remember correctly.
