Vcds
james400
Vcds
Post by james400 » Sun Dec 01, 2019 4:23 pm
So having abit of trouble with vcds I'm trying to code things in like the front fogs and its saying it's done but if you go back on the coding it's the original codeImage??Image
Re: Vcds
Post by Doc » Sun Dec 01, 2019 5:24 pm
This is usually a sign that a module does not support the option you are trying to enable.
Are you sure that CECM can run fog lights?
james400
Re: Vcds
Post by james400 » Sun Dec 01, 2019 5:46 pm
It give me the option in the dropdown menu?
Re: Vcds
Post by Doc » Sun Dec 01, 2019 6:47 pm
Ross-tech, the makers of VCDS, haven't made a label file for each and every module. VCDS shows options for the entire range of modules, some of which might not be available on that exact module.
james400
Re: Vcds
Post by james400 » Sun Dec 01, 2019 6:53 pm
Ok cool I do have a hi line cecm off the Touran I got my aircon stuff cant remember tho how to recode another cecm is there a how to on it??
r1lea
Re: Vcds
Post by r1lea » Sun Dec 01, 2019 7:17 pm
3c8 937 049e supports fogs on a Passat
