Turbo boost gauge fitting
racman
Post by racman » Sun Dec 01, 2019 4:56 pm
Hi guys has anyone got information on where is the best place to tap into the induction system for a boost gauge as I’m having intermittent loss of power and having a gauge will be of great help cheers 🍻🍻
I come here for R&R
Bionicman
Re: Turbo boost gauge fitting
Post by Bionicman » Sun Dec 01, 2019 9:17 pm
Hi racman, I have not got a turbo boost gauge on my Caddy but if I was to fit one I would tap in to the intercooler rubber/silicon hose at a convenient place. I don`t think it makes much or if anything at all where you tap in as in theory it should be the same pressure at either side of the intercooler but I stand corrected on this.
Post by Doc » Sun Dec 01, 2019 9:24 pm
To save making a hole which might cause more problems you could get one of those CANbus gauges and monitor the boost pressure that way.
racman
Post by racman » Tue Dec 03, 2019 12:35 am
Cheers Doc I’ve thought of that but the ones I’ve seen are money I just want a simple gauge I’m going to take the plenum off and fit a nipple no different than doing a meth system I guess cheers anyway 👍
I come here for R&R
