Blower failure query
thecolourpurple
Post by thecolourpurple » Mon Dec 02, 2019 12:43 pm
Hi all
Blower packed up. Zip, zero function. Is this likely to be an electrical issue or electronic/control module problem?
Any help/advice gratefully accepted
Bionicman
Re: Blower failure query
Post by Bionicman » Mon Dec 02, 2019 1:07 pm
Does it work on full speed?
thecolourpurple
Post by thecolourpurple » Mon Dec 02, 2019 1:45 pm
Nothing at all. Completely dead.
Post by Doc » Mon Dec 02, 2019 4:24 pm
That will be a blown fuse or failed motor.
Have you a way of testing voltage at the motor plug?
thecolourpurple
Post by thecolourpurple » Mon Dec 02, 2019 6:34 pm
Hi Doc
Not in a position to do anything till next weekend unfortunately. I'll check out your suggestion & report my findings.
Thanks for the assistance.
thecolourpurple
Post by thecolourpurple » Tue Dec 03, 2019 7:57 pm
thecolourpurple wrote:Hi Doc
So I have an update to my problem. Took van to a good friends workshop this morning & so far the following has been found:
It appears that there is no voltage coming off the control module to the blower . Hope that sounds right , I'm not that clued up. Also found that rear sensors have also stopped working & the high beam in the ' locked' forward position too.
Can anyone confirm that it could be the module & all these issues are linked?
