Hi guys,
New to the forum, and have the modifying bug already...
Is there also a 'How To' on this conversion (probably on the technical section but awaiting an upgrade to be able to view).
I've a 1.9 TDI (BLS) which i'm in the process of buying parts to convert from 5 to 6 speed. So far i have the following:
FMH O2m Gearbox (Golf MK4 150PD), Driveshafts, starter, alloy gearbox mount, shifter linkage ends, bolts, flywheel & Clutch.
Is there anything else needed? Concentric slave cylinder?
5 to 6 speed gearbox conversion
Re: 5 to 6 speed gearbox conversion
New gearbox oil.
got that one..
