Lads im sure this issue has been covered before but i can find info on my exact problems so need help!
So i have got installed & modified touran door cards for my 2010 (base line) caddy along with touran door loom & regulator on passenger side & caddy door loom & regulator on drivers side (All the breaker had in stock) I have wired a power wire from fuse box to door pillar plug on drivers side (yet to do pass side) but the only switches that light up is the electric mirror switch, nothing else illuminates when i turn light on, i understand its to be coded but is there a reason why the switches dont light up?
Any thought will be a great help. its putting my head away!!!!!
Door card/electric window retrofit
Re: Door card/electric window retrofit
update or electric window retrofit
I had the wrong drivers side loom in which was fu*king about with the electrics, i was actually able to find a stander caddy loom with electric windows, plug & play. I have brought power to the door looms and everything seems to be working fine apart from door lock & unlock button is dead, dosnt work at all.
Any one have any ideas??
thanks
thanks
