Hi all, I have a 2008 mark3 1.9tdi caddy
All of a sudden my headlight switch is doing nothing , the minute I turn ignition the low beams and dips come on automatic and this van does not have auto lights , front dogs and rear fogs are not working ,no loose connections and all bulbs are fine ,anyone any ideas?
Headlight switch doing nothing
Re: Headlight switch doing nothing
Hi, welcome to the forum.
Sorry to hear about the trouble with your headlight switch.
If you have no access to diagnostics, it maybe worth trying to borrow a switch from another VW owner if you know one with a similar generation vehicle. Anything Golf or similar size will have a switch that will be compatible with yours.
They are dead simple to remove, just push in at the O position and then rotate clockwise while pushed. The switch should latch and then pull out.
Hi doc ,Thanks for the reply ,I have access to vcds and through a full scan and center electrics I’m getting no faults down to the lighting switch ,just a indicator bulb and other nit pickie bits ,I’ll try a different switch when I get the chance to source one for free
hi Doc ,diagnostic (vcds) isn’t showing anything up to do with lights ,tried swapping with a different switch and still no joy,checked fuses again under steering colum and also under Bonet in other fuse box with still no joy , I think it may be brang to auto electrician as I’m out of ideas
Did you check the light switch measuring blocks with VCDS, to see that the switch function is actually being read by the BCM?
- Peli
Go to [Select], [09- Cent. E;ect.] and the [Meas. Blocks]. With the [Up] and [Down] you can scroll throw the Groups. I don't know the number you are looking for.
Maybe you can figure i out with the text by the blocks.
Still haven’t got a chance to try the live data , anyone off the top of their head know where headlight relay is
