Hey guys just wondering what is required fitting a different cluster I have an 07 tdi I’d like to upgrade it but I’m not sure what has to be done and I live in Australia so I am very limited on what I can acquire down here
Fitting different clusters
Re: Fitting different clusters
Would something like this be easy to fit and code
I’m also looking to buy this
The description says genuine Ross tech is that all I need to start coding and using vcds
- r1lea
Firstly Vcds is no good on its own for swapping clusters, vag commander is also required
Secondly that’s not a genuine Vcds
the only way to make that cluster (that is after 2010 white cluster) work in your van is to upgrade your ABS pump, fit a adapter loom and replace tranponders chip in your keys. The tools to do this are not cheap, this won't work with the PIN procedure
vcds.diagnostic@gmail.com
Which ones can I fit
