Page 1 of 2
Wind noise
Posted: Tue Jan 07, 2020 1:08 pm
by Bubbles
Hi All
Picked up my 2018 Black SWB Caddy on 14th December only 2800 miles on the clock from a local dealer .
My problem is wind noise I have narrowed it down and discovered it is caused by the drivers side wing mirror.
It’s a high pitch whistle and is very irritating. Has anyone got any suggestions as to how to rectify this issue ?
Re: Wind noise
Posted: Tue Jan 07, 2020 1:43 pm
by Giddy
Just type in "mirror whistle" in the search box and you'll get lot's to read. It's a common thing for caddy...
Re: Wind noise
Posted: Sun Jan 12, 2020 8:58 pm
by Bubbles
Thanks , visited the VW van centre on Friday and they were familiar with the problem . To solve it they are ordered new mirror covers for both side and then they are being colour coded at their body shop . They say this will solve the wind whistle problem because the paint will be thicker and not machine finished as they are when they come of the assembly line . Apparently the smooth finish causes the whistle and the new covers won’t be as smooth and will disrupt the wind pattern and get rid of the whistle
Re: Wind noise
Posted: Wed Jan 15, 2020 10:36 am
by Gaztheplumber1
Giddy wrote:Just type in "mirror whistle" in the search box and you'll get lot's to read. It's a common thing for caddy...
Does fitting the window deflectors help with this issue? Noticed the whistle on mine saw a few caddys on ere with those fitted
Sent from my H3113 using Tapatalk
Re: Wind noise
Posted: Wed Jan 15, 2020 11:34 am
by Barbel330
Bubbles wrote: ↑Sun Jan 12, 2020 8:58 pm
That’s a new one on me, sounds a bit far fetched tbh so I’ll be interested to see what the outcome is.
As far as I know it’s a design fault and all caddy mirrors whistle. People stick rubber dots in strategic places and foam tape in the gaps to try and stop the noise but I’ve no idea how successful they are. A sure fire way to stop the noise is to upgrade to the smaller aero style mirrors which also look vastly better than the giant square ones.
Re: Wind noise
Posted: Wed Jan 15, 2020 8:22 pm
by Giddy
@Gaztheplumber1 Don't know mate, never had them on mine. I would though, they have potential to create more wind noise rather than reduce it
Re: Wind noise
Posted: Wed Jan 15, 2020 8:28 pm
by Gaztheplumber1
@Giddy yeh thinking of putting some onto mine. Very true not sure if that would annoy me tho
Re: Wind noise
Posted: Mon Jan 20, 2020 8:06 am
by Philt32
I’ve got genuine wind deflectors on mine (well the ones bought from a dealership) and it doesn’t stop the mirror whistle
Re: Wind noise
Posted: Mon Jan 20, 2020 8:34 am
by Gaztheplumber1
Ok
thanks for the update
Re: Wind noise
Posted: Mon Jan 20, 2020 10:40 pm
by sheepy92
Painting wont make a blind bit of difference well it didnt when i painted myn its the shape of the mirror unfortunately not the best aerodynamic effeciency i forked out for some life mirrors theyre the nuts
Re: Wind noise
Posted: Mon Jan 20, 2020 10:47 pm
by Gaztheplumber1
More good info cheers
Re: Wind noise
Posted: Fri Jul 10, 2020 4:28 pm
by Bubbles
Well the new painted mirror covers provided by VW have improved the noise a bit ! . Now with the windows up and closed , I can no longer hear the continuous high pitched whistle . However if I open the window while travelling I can still hear the whistle but it’s not as loud as before .
Am tempted to go back to VW as the van is still under warranty for another year and then say to them that they need to replace those mirrors with something more aero .
You thoughts please ?
Re: Wind noise
Posted: Fri Jul 10, 2020 8:32 pm
by gazza31112
Other than the sticky back velcro patch people put on, your only other option is the aero mirrors. Look so much better than the Dumbo ears.
Re: Wind noise
Posted: Sat Jul 11, 2020 9:09 am
by SunEye
What fixed my mirror whistle completely was sticking Velcro (the fluffy piece) in the gap between the mirror and the mounting.
Re: Wind noise
Posted: Sat Jul 11, 2020 9:38 am
by Papa Bear
I did that, it reduced the whistle, added a second layer and it stopped it for a while, now come back at a higher pitch but quieter. Maybe I have inferior Velcro
Going to look later to see if I need a third layer , if not I’m putting insulting tape over it for now
