Interior light switch
Re: Interior light switch
Post by gazza31112 » Mon Jan 13, 2020 8:52 pm
Changed rear headliner about a month ago added 8 spotlights and removed standard light.
If I'm honest I bodged it in, twisting wires together and, if I remember rightly connected two standard wires together to one spotlight wire then (brown i think, to the other) I noticed yesterday it turns on with unlocking, and off with locking, otherwise it's on when van is on, didn't realise this before as i have made a solid bulkhead, when im the back with the barn doors open and keys in the lock the van locks itself after about 30 seconds and lights turn off
(Picture 1)
Didn't touch front light.
Then over the weekend I removed and carpeted front headliner and overhead storage, while doing this I thought I'd add a switch to 2 spotlights I mounted into headliner
(Switch on picture 2)
All this runs fine, is the only light I have so have been using it alot!
Fused and wired straight from battery and an earth
After installing those I went to remove interior light and snapped a connector which connects to the sliding switch (so it's dead).
But I though no worries I can just stick to my plan of adding another spotlight to the same spot ( I carpeted over the opening, plan was just to stick a spotlight in the same place)
Then cut the standard connector off and tried wiring it in to the spotlight. Couldn't work it out, ended up blowing 3 fuses trying every combination wires (yea I know lol) that's when I started this thread.
When you sent the drawing over I tried that, wires were only twisted together at that point.
Stopped off after work today to get some proper connectors and to get a new switch, tried again...... Got light but still not doing what I need it to do.
I just want it to turn off!!!!! ImageImageImageImageImageImageImageImage
So that's were I am
Could it be something to do with the back?
I wouldn't have thought so considering the front standard light worked fine for all this time?ImageImage
Post by gazza31112 » Mon Jan 13, 2020 9:21 pm
I haven't got one at the moment, but could easily pick one up tommorow.
Wouldn't know what to do with it lol, I can test but wouldn't know what readings I'm looking for lol?
Could it be Iv bodged the back? Could it somehow be mirroring the rear wiring? If I fixed the rear properly as in your diagram do you think this could fix the front?
Iv read a previous post of a user (which you sent the same image to) saying he's basically done what I did in the back, lights come on when unlocking and go off when locking.
Could it somehow be running off that setup in the front?
So if I fix the rear, maybe the front would follow suit? I'm just clutching at straws now mate lol, when you asked about the back, it just made me thing maybe?
Giddy
Post by Giddy » Mon Jan 13, 2020 9:24 pm
I think first you have to undo those wires in the back, it's definitely wrong to leave them like that, you may blow up something. I think we have to start from the beginning and do it properly.
If you want to have the lights On all the time thats fine, but use only the Red and Brown wires, leave the blue disconnected. That's for the back. Or wire in the switch as I posted earlier. So you'll have an option to have it permanently On or On with open door.
I have a feeling this will sort out your cabin light issue too.
Instagram: @giddywagen
Post by gazza31112 » Mon Jan 13, 2020 9:29 pm
Yea that's just dawned on me aswel!!!
I'm all for doing things properly but always been a bit of a bogde when I didn't know how lol.
Ok mate will get on that in the morning and see how it goes, I'll remove rear headliner and wire it up to a switch like you said to do in the front.
Then hopefully that will make the front work right!!!!
Thanks alot for your help mate, I really appreciate it, I'll get back to you tomoz
Giddy
Post by Giddy » Mon Jan 13, 2020 9:32 pm
No worries mate, hope it all goes well for you :)
Post by gazza31112 » Tue Jan 14, 2020 4:46 pm
Switch in back same as front, no change, pulling my hair out lol still either on or off, doors make no difference
Giddy
Post by Giddy » Tue Jan 14, 2020 5:54 pm
Do you mean it stays always on in both switch positions?
Post by gazza31112 » Tue Jan 14, 2020 6:00 pm
Na mate, either on, off or very dim like my post the other day with the pics. When it's on, I can lock the van, it will go off, unlock the van it will come on, and stay on, forever, now same with the back.
The back didn't have 2 wires twisted together after all, the blue wasn't in use.
Now the back is wired in exactly the same as the front, with everything in the same positions
Giddy
Post by Giddy » Tue Jan 14, 2020 6:06 pm
Ok, so when connected to Red and Blue wires it's only dim light? If that's the case, I'm afraid you may have damaged that part of the control circuit by shorting red and blue together...
Post by gazza31112 » Tue Jan 14, 2020 6:17 pm
Yep that's how it's looking then, shouldn't the dim light still turn on and off with the doors? I'm gonna get a standard switch soon and try it with that cause I'm sure that worked after I played around with the back. We will see!
Post by gazza31112 » Tue Jan 14, 2020 6:18 pm
If that is the case.... Is there any fixing that?
Giddy
Post by Giddy » Tue Jan 14, 2020 6:36 pm
In the worst case scenario you'll need to replace BCM. Perhaps it can be repaired, but that's not possible to tell without actually looking into it.
Post by gazza31112 » Tue Jan 14, 2020 6:42 pm
Ok mate I'll look into it, thanks for your time and help I appreciate it
Giddy
Post by Giddy » Tue Jan 14, 2020 7:02 pm
No worries mate
Post by gazza31112 » Wed Jan 15, 2020 4:24 pm
Fixed it!!!!! Was reading up and a few places said to disconnect battery for 15 mins and that can sometimes reset BCM, did that then thought to fault check with the carista cheap diagnostic thing I got off eBay, alotttt of interior light faults came up, reset them all and what do you know, It only works!!!
What a relief!
Thanks again for all the tips mate I'll remember that in the future haha
