Caddy van false floor
Cy Russ
Post by Cy Russ » Sun Jan 12, 2020 4:51 pm
On the caddy van, where the foot well would be on a life version what is there? I'm assuming it's a welded in false floor but is there storage there too? Any photos of this area? Is there enough room to fit a night heater there?
Tia
Dalero
Re: Caddy van false floor
Post by Dalero » Sun Jan 12, 2020 5:12 pm
Without actually measuring I would say width 400mm x length400mm height 175mm.
Cy Russ
Post by Cy Russ » Sun Jan 12, 2020 6:11 pm
Thanks, sounds pretty big tbf.
Emgee48
Post by Emgee48 » Mon Jan 13, 2020 9:35 am
That’s about right, I got a leisure battery under the floor on its side, 400w x 240h x 170d . That fits easily under the floor and you have at least another 200mm in front of the false floor up to the back of the seats. Plenty of room for a heater to be installed.
Cy Russ
Post by Cy Russ » Wed Jan 15, 2020 9:55 am
Emgee48 wrote:That’s about right, I got a leisure battery under the floor on its side, 400w x 240h x 170d . That fits easily under the floor and you have at least another 200mm in front of the false floor up to the back of the seats. Plenty of room for a heater to be installed.
Sounds like a handy space, I'll be converting the maxi into a mini camper so any space will be ideal
